Page 7 of 33 FirstFirst ... 5678917 ... LastLast
Results 91 to 105 of 481
Thread: Celica Brake Upgrade
  1. #91
    south australia
    Default Re: Celica Brake Upgrade
    is it like the nodule on the rx7 caliper that if you shave off, you open the gallery between the 2 pistons?
  2. #92
    No idea, thats what im trying to find out.
  3. #93
    Wezelton Grease Monkey
    Sorry to keep spaming but HQ front bubs with a hilux 5 stud axel/diff.. mmm GTR wheels. Got any idea on offset with the HQ hubs ? also with the hilux diff ? i got a ra60 just wondering if the hilux diff would give me more track
    Wes.
    Bitch, come over here and have sex with Charlie Murphy..
    Im Rick James bitch!
  4. #94
    HQ im pretty sure is 5x120 not 5x114.3 which is GTR PCD.
  5. #95
    5x108
    will double check measurements... still have the hub.
    Black Betty >HERE!<
    (\__/)
  6. #96
    ah damn. pitty.. only want to run some wide rims that dont cost heaps like my dishies did.
  7. #97
    Either way, its not 5x114.3
  8. #98
    Washington, USA
    Thumbs up Re: Celica Brake Upgrade
    Quote Originally Posted by Wezelton
    Also ae86 front inserts are the same. Definetly same diameter not 100% on length but if someone wants to look up codes, im pretty certain it'll be there too. Im running agx mr2 inserts, havent had a chance to run em but there nice n short and very stiff
    i'm running the shortened ae86 strut tubes and brakes with the sw20 turbo AGX's ( ftw!!! )
    the tubes needed to be cut 1 7/8" for the shorties to fit right. No spacers and still have a couple of threads showing on the top nut. its a nice snug fitment.
    these are bolted into my RA21. also have the universal 2.5" GC coil-over setup with 7"x300# and the ride is very firm. But not harsh. I drive around on setting #2 and autoX on #3 or #4 depending how smooth the course is.
    But now that the hybrid is going turbo i need more brakes. those lil rotors just wont handle it.
    72 RA21, 77 RA29, 78 RA40, 79 RA42, 83 RA65c, 85 RN60
    81 RA42 race car, 04 F150 supercab tow rig.
  9. #99
    When i said that the ae86 might be the same length, i meant uncut. just incase lol. I only cut my struts 40mm and im running a 20mm spacer, but i got a hole drilled out so i can run it at the top of the strut so the insert is shorter pretty good huh
    wes.
  10. #100
    guys im considering giving this all a go,
    i have struts and calipers, just need to sort out the rotors,
    the best way to go seems to get the RDA slotted rotors and get them machined down and re drilled? is filing out the calipers really that bad?
    all going into a TA22 so what should i do about the booster? and will teh existing suspention match up? im about to redo the shocks and springs soon anyway
    Quote Originally Posted by merc-blue
    Fileing down the calipers is a bad idea.
    From what i can see there isnt enough meat on them to do this safely.
    Better to loose a bit of braking capacity than possibly have them fail all together.
  12. #102
    tas
    im thinking of doing this conversion so here is a few questions. Will the hilux calipers bolt onto the corona caliper mounts? and will 14'' wheels still fit?
    sorry if thse have already been answered.
    cheers, lloyd
  13. #103
    Quote Originally Posted by ke30king
    cheers, lloyd
    THATS EXCACTLY WHAT I WANNA KNOW.............do 14" still fit?????????
    Yeah, 14s will still fit. I run 14" rims on the race car, and while its close they will fit.
    The MA61 stockers will fit too
  15. #105
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Yes - I agree 110% its not good to file away material from the inside of the calipers, so that is why I machined down the rotors instead.
    And yes, your original 14 inch steelies will fit except mine caught on the rotors on two places as I drove slowly down the driveway, testing my work for the first time.
    It looked like where the centre section of the wheel was welded to the outside of the wheel, that was fouling the calipers.
    What I did to fix this was to put bright water colour paint on the inside of the rims all around where they were most likely rubbing, refit them, drive up and back the driveway for 30 metres and them take them off again.
    Where the paint was missing was the part rubbing on the calipers.
    20 seconds work with a 4 inch angle grinder, just to take those high spots off, wash the water colour paint off, and never a problem since.
    Mitch.
    RA23
    1G-GZE
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
