Page 11 of 33 FirstFirst ... 91011121321 ... LastLast
Results 151 to 165 of 481
Thread: Celica Brake Upgrade
  1. #151
    User Conversion King
    NWA
    Default Re: Celica Brake Upgrade
    lots of models have the "stronger" stub axles. depends what brakes you want.
    RA23/28/40/60/65
    MX62/73
    XT130/ST141/RT142/RT132
    all the above cars have the same stub axles....the strut dimensions differ a little throughout said models
    hello
  2. #152
    Wezelton Grease Monkey
    Why the hell does anyone buy STOCK springs and shocks, ?? WHY!!! Man if anything, after market shocks for a start are great and also getting even falcon springs are good. providing you do everything right.. My lesson learnt is NEW stocks SUCKS...
    Wes.
    Bitch, come over here and have sex with Charlie Murphy..
    Im Rick James bitch!
  3. #153
    Washington, USA
    any ill effect of using a rotor that sit on the hub and hangs backwards? instead of bolting to the inside of it?
    72 RA21, 77 RA29, 78 RA40, 79 RA42, 83 RA65c, 85 RN60
    81 RA42 race car, 04 F150 supercab tow rig.
  4. #154
    yeh i know vl wheels are different pcd. but i got these for a real good price, so im willing to fork out the extra bit getting all fours converted to suit... but im not gonna go and do all that, if in the end the rims are the wrong offset. i might get a quote on changing the offset from simmons... if its gonna be to much, then the rims loose the appeal... ahahah
    ive got a mate who does 4x4 lifts. i was talking to his bro about brakes and stuff, he said they might be able to get cheap bits and peices. so im gonna talk to him about getting the hilux 4pots. if he can get them cheaper, ill grab a bunch?
    jase
    JZA023
  5. #155
    im about ready to put all my bits in, just waiting on new bushes and bearings,
    but i sitll havent worked out teh booster/MC issue what are people running ATM who have compleated the brake upgrade i also plan on replacing the stock bias divider thing with a proper adjustable bias valve (to fix bias problems)
  6. #156
    Tasmania
    Ok I'll probably be out of line here but if your brakes are doing the job there supposed to do then why upgrade?Ok I understand if you are using your car as a street/strip or track thats fine but if they are only a daily driver most Toyota brake systems are more than adequate.I've owned and raced quite a few Toyotas and the brakes were only upgraded to either twin spot calipers and decent pads,all worked fine,I even had an old Crown wagon which had 4 wheel drums with booster and that stopped better than some of the ones I owned with discs.I'll probably get shot down on this one but hey if its doin the job leave it alone.
    Cheers Brett.
  7. #157
    most of us are putting in 1GGTE.
    factory max power 60rwkw
    1GGTE - 140rwkw
    not to mention i can name 2 1g's that are doing 220+
    hence the brake upgrade
    Black Betty >HERE!<
    (\__/)
  8. #158
    Tasmania
    No thats fine when it comes to increase of horse power I've done the same in my time.its just that the cost of things these days it pays to to be very particular in what u want and wat u want to pay.
    Cheers Brett.
  9. #159
    NWA
    Quote Originally Posted by merc-blue
    im running a RA28 celica brake booster in my RA40. thats teamed up with a GZ20 soarer master cylinder (1") ....works great
    i believe MA70 supra MC is the same as GZ20
    hello
  10. #160
    NWA
    Quote Originally Posted by crowncustom
    Cheers Brett.
    the stock celica brakes are okay for 'granny-smooth-style' brakeing, but when you go to pull up from higher speeds (as the 1g helps you achieve ), they fade very quickly.
    im thanking myself i have the 4spots on because one afternoon a cyclist decided he wanted to turn right through a round about (in front of me). i was only doing 60 but he was so short, he was hidden behind the traffic island hedge until the last second. when i smashed the brakes on, the car pulled up on a dime with SFA pedal effort . that kind of braking with stock brakes requires a very decent amount of effort(rubber hoses expanding etc.). and the more effort that is required, the more time it takes your leg musles to build the strength.
    so for $500 worth of brakes, the mooron cyclist didnt get hurt!
    hello
  11. #161
    Does anyone know of any performance style drum shoes to suite RA60 ? I havent had time to look but if anyone knows off the top of there head that would be great.
    Not that alot of you (most) will like my plan, im putting in a RB20DET. Honestly its cos i picked it up cheap but then started to realise how well it works out in my car. Main reasons are the exhaust and intake are the right way round and also there are plenty of bits for the rb20. I will post pics when the motor starts to go in!
    Wes.
  12. #162
    Quote Originally Posted by Wezelton
    Wes.
    Yeah I am looking at upgrading the drums(well just putting new shoes in them and whatever else you do to drums to freshen them up). When and if I upgrade my fronts.
  13. #163
    Guys, is any one running just a RA series booster and MC, i picked one up from pick-a-part the other day (its in amazing shape) out of a RA and i can see why you would bother with the MA70 MC the RA MC seems to be quite large, or am i just used to peewee Ta22?
  14. #164
    NWA
    if you run the hilux callipers, they require quiet a bit of fluid flow.
    however you can decrease the rrequired pedal effort required by decreasing the mastercylinder bore size size.
    so where do you draw the line??
    from experience, everyone says a 1" bore is best...but you could always see how happy you are with the RA 15/16" (?) one
    hello
  15. #165
    hey, anyone who has this on a ra23. wat offset rims do u run? and wat width tyres...
    im gonna try and get my simmons re-set, so i wanna see how much i have to have them changed.
    it may not be worth it though at 450 a corner, plus the original purchse cost, its almost better for me to get them from simmons direct, custom from the start
    JZA023
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
