Page 17 of 33 FirstFirst ... 7151617181927 ... LastLast
Results 241 to 255 of 481
Thread: Celica Brake Upgrade
  1. #241
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Default Re: Celica Brake Upgrade
    A competent machine shop should be able to cut off and rethread your struts.
    Only ones that I have seen shortened and rewelded were being converted to coilover, the join was inside the threaded sleeve that was going to be put on so reinforced.
    regards
    jon
  2. #242
    would be cheaper than getting them professionaly welded right?
    EDIT
    i just realised either way i would have to move the lower spring retainer casue thats whats causing the be too long more than the tube
  3. #243
    Jun 2006
    Maybe a bit cheaper, better finished product would be the main difference I recon with no joins.
    A bit of stuffing around to set up though, would need to grip base of strut in chuck and support end in steady.
    regards
    jon
  4. #244
    yeah i might just get my front springs slightly shorter to make up for the length
  5. #245
    Ok, just curious now, on other peoples upgrades do the calipers protrude infront of the hub face?
    I have had to use a 3mm spacer to get my wheels to clear the front of the caliper....
  6. #246
    are we talking xt130/hilux/pug ?
    i can check in the morning.
    Black Betty >HERE!<
    (\__/)
  7. #247
    yeah, XT130/Hilux/Pug
  8. #248
    i've just been working on my baby, was about to swap the booster and master cyclinder from the GA70 for the stock ones, although now it appears that the supra booster is much too large, i'm certain i remember reading once upon a time that the GA booster and master cyclinder were a straight bolt up??? now i suspect that it was just the master cyclinder and not the booster
    anyone care to fill me in?
    '77 RA28LT #2 ← 2.2L 18RG...
  9. #249
    master bolts up ... booster id assume too large for that corner.
    ive got ma70 master on my std booster.
    Black Betty >HERE!<
    (\__/)
  10. #250
    yeah... i was afraid of that, bugger using the stock booster, i want GOOD brakes... anyways, i think i have a plan... besides, i took time to clean up the GA booster paint it and scrub up the heat shield....
  11. #251
    The stock booster wouldnt be overly bad, but the ultimate is unboosted brakes... as i found out yesterday.
    The ideal MC for unboosted (in my opinion) is a 240K master, its 7/8th and the pedal feel is beautiful.
    This is what it looks like in the bay:
    and mocked up
    and im just running a small rosejoint to secure the rod in place
    Overall i think that the unboosted setup works far far far better than any other car ive driven with boosted brakes, its much more consistent and steady, with beautiful feedback.
  12. #252
    Black Betty >HERE!<
    (\__/)
  13. #253
    Classic Not Plastic Domestic Engineer ace's Avatar
    Looks Hot!!!!!
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
  14. #254
    Yup thought so, protrudes the same distance as mine, makes fitting my +2 offset Cheviots over them hard.... ohwell.
  15. #255
    Hoppers Crossing
    thats wierd i didn't have that problem ta-022
    what are your hubs from?
    mine are are rt132
    wondering if there is a diff with the hubs???
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
