Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 91 to 105 of 136
Thread: Toyota A series differentials (~1995 onwards) ratios? can i use G series crown/pinion
  1. #91
    Default Re: Toyota A series differentials (~1995 onwards) ratios? can i use G series crown/pinion
    From the look of that list above, there's 5 different cases for JZA80's.
    2 for 6 speeds - 14080 & 14100
    3 for 5 speed and auto - 14100 (w/lsd), 24030, 24031 & 24040
    Now need to cross other non supra models, esp Crown UZS's and Century GZG's for ratios. May turn something useful up since they aren't the usual JZ engine and possibly different g'boxes.
    Friends
  2. #92
    vic
    Runs out to the shed to check my UZS diff. LOL
    Dave
  3. #93
    if its a 4.7 + and suits a 84 jza80 A series case and bolts to a torsen LSD that fits said case that didn't come with factory LSD consider it sold.
    Friends
  4. #94
    I'll bet at least a couple of those cases are different in only minor details
    eg, they improved the breather to stop oil getting out, also some cases have fins, others dont
    But yeh it makes no difference as far as cross-compatibility goes
  5. #95
    Act
    If i change ratios in my UZS131, how did I go about getting a compatiable speedo gear drive.
    I want to lower the ratio in the UZS131 and getting it reving less around town
  6. #96
    Use a Jaycar speedo corrector?
  7. #97
    Act
    yeah an idea I am just intrested and should start another thread about it.
    As i want to know how it will effect the air bag suspension, abs and most importantley the auto shift points etc
  8. #98
    vic
    Hey ed how is your VVti 1UZ going , is it tonken yet ??? or are you still sorting out the diff.
    Dave
  9. #99
    Dave you cave dweller.
    Quote Originally Posted by ed_jza80
    well, everything can slow down an order of magnitude as we now have to REBUILD THE FUCKING ENGINE
    fucking conrods
    fuck fuck
    fuckity
    fuck
    sounded like she did in a bearing, and by the time a figured out it was a rod (on the freeway after maybe a 5sec 7500rpm squirt) i started babying it, then squeak! jammed
    seized solid
    can only think its spun a big end
    yup, am anticipating x1 crank and x1 rod plus a set of bearings and seals and a re-look at the oil lines
    dont think it was oil pressure, but not sure, honestly wasnt looking
    anyone got a stock crank hanging around?
    for now, ill pull it out on sunday (wooofucken-hoooo, thanks always a bundle of fun) take the sump off and have a look, but otherwise ill rack it up onto a pallette and send it back up to yager to diagnose and rebuild....
  10. #100
    vic
    Im just stiring him Greg
    Dave
  11. #101
    you're a cruel man
  12. #102
    Hmmm after reading this and other G/A series threads i'm don't think i'm any wiser but if someone can confirm:
    A and G series R&P are NOT interchangable?
    What was/is tallest G series ratio delivered locally?
    and what was it in?
    fingers crossed
    [QUOTE=JustenGT8
    fingers crossed [/QUOTE]
    You got it although if you have a A Series Hilux R&P it will interchange with a G series Hilux if the offset is correct. A series R&P from Supra/Soarer/Aristo is not interchangable with Hilux R&P.
    Jealousy is a curse
  14. #104
    Ok thanks that's a start. Offset can be cured with a spacer plate easy enough i suspect but only an issue if the tall ratios i'm chasing are found in the A series Hilux diff eh.
    So can anyone shed light on what models/years to be chasing for the taller ratio'd G series (or hilux A series) diffs?
    PS full spool on the way from US...recent dollar crash hurt a little, wish i had ordered a few weeks ago Still cheaper than Oz sources but a 1/3
    What did it cost you all up (aud) Justen?
    As discussed, sounds like you'll be the pioneer on the irs front
    AFAIK the tallest G series hilux was 3.5 a mid 90's auto diesel, possibly twin cab?
    Pretty sure Rod has one in his RA28. Have a look at his members ride thread.
    Or was it 3.7?
    Phil
    By The Witzl in forum FAQ
  2. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 12:58 PM
