mine too
lol my t series gearset i just bought is 41201-##### lol @
First 5 digits tells you what the part is - e.g. 41201 means Final Gear Kit, Differential Rear.
It has nothing to do with compatibility at all - just means they have the same name.
Pick any part on different models and thet start with the same 5 digits.
An experienced parts man knows them without looking them up - or al least my local bloke does.
Graham D
Lexus RX350 (no mods yet !!!)
Lexus IS200 / 2.5GT-T (1JZGTE VVTi + Getrag 6 Speed)
Lexus IS200 (wife's car and no mods allowed !!!)
Suzuki GSX750-F
mine too
i pulled three hundred rocks from the land to build my house
i walked quiet through the forest like a tiny quiet forest mouse
the oceans will rise
please stand by the shore
What is the full part number for your CWP? Deciding between the 4.557 and the 4.7 TPS one.Originally Posted by SeptemberSquall
I'd like to add the newer Toyota diffs to my axle database, but if I'm reading this thread correctly there's no reliable way to identify a diff type based on the newer axle codes. Or is there another way it can be done? It would be great if there was some way to get all the information into one place and eliminate all this confusion.
Norbie!
www.norbie.net
Hmmm, 300km/h at 8000rpm with a 4.1:1 ratio. Are you sure about that Ed? I calculated the top speed of my Supra and it was about 310km/h at 8000rpm with a 3.58:1 ratio. Are you using insanely tall tyres?Originally Posted by ed_jza80
Norbie!
www.norbie.net
Apparently the newer EPC's have a way of relating the codes to models that the part was fitted to. Thats where the info for the model cross refs I got were from so I guess thats a start.Originally Posted by Norbie
Friends
Hence my thread - http://www.toymods.net/forums/showthread.php?t=37721Originally Posted by Norbie
well the 4.55 gearset is in the country. should be easy enough to get a parts dept to get it into their store, pull it out and take a look
../delete/ban
tech moderator
You'd want the R&P out of an RA65 Manual (3.58) or MZ12 Auto (Diff has G series input flange on it tho, but if you want the R&P shouldn't effect ya!). Both a F series IRSOriginally Posted by grahamd
I've got a MZ12 3.58 that I'd sell, swing me a PM if interested (~125,000km)!
Why would he want Rack & Pinion out of an RA65 for his lexus?Originally Posted by wilbo666
better off with the C&P for the diff![]()
Originally Posted by WHITCHY
I was thinking Ring Gear and Pinion...
Rear wheel steer conversion?Originally Posted by The Real Roadrunner
Friends
OEM t series gear ratio kitOriginally Posted by takai
comes with ring gear and pinion
list varies but around 700 buckaroos
toyota
# 41201-29406 3.308 final gear ratio
# 41201-29287 3.583 final gear ratio
# 41201-29227 3.727 final gear ratio
# 41201-29237 3.909 final gear ratio
# 41201-29197 4.100 final gear ratio
# 41201-29207 4.300 final gear ratio
# 41201-29626 4.556 final gear ratio
# 41201-29637 4.778 final gear ratio
trd
41201-TA001 4.625:1
41201-TA002 4.875:1
41201-TA003 5.125:1
41201-AE851 5.375:1
sorry for off topic
700hp plus handbrake gives you that option.Originally Posted by clubagreenie
You have a 700hp hand brake? Really quick 100 to 0 times?
Friends
