Page 9 of 10 FirstFirst ... 78910 LastLast
Results 121 to 135 of 136
Thread: Toyota A series differentials (~1995 onwards) ratios? can i use G series crown/pinion
  1. #121
    Default Re: Toyota A series differentials (~1995 onwards) ratios? can i use G series crown/pinion
    UCF20 gears are same as Supra A Series
    Jealousy is a curse
  2. #122
    and we are dead 100% sure that the Supra A series CW does not swap with the G series CW right?
    That is correct
    Jealousy is a curse
  4. #124
    OK thanks. I can strike the 3.27 off my list then and it appears only the pre 1994 celsior/crown/LS400 will have the G series and i believe the tallest they came in was a 3.9.
    I'm down to the 3.58 as an option in the RN80/90 Hiluxes and RZN161 tacoma as well as the 3.42 in the RZN140/50 Tacomas as definites.
    Some reference to 3.07 and 3.42 in the late 80s early 90 4Runners but only in the US as far as i can tell.
    None of the part numbers listed above in tables appear to work in the local toyota dealers computer?
    Must be US market only then, know anyone in the States?
  6. #126
    Penrith BC
    jzx90 and jzx100 A series are compatible with G series C+P
    unfortunately with the US 4wd market they are commonly referred to as the "V6 diff" or the "4cyl diff" etc... makes life a bit hard. and i dont exactly know what the tacoma/sequolia/wtf name whatever actually refers to either
    ../delete/ban
    tech moderator
  7. #127
    So does that repetition mean you are really really really sure Ed
    and you know this how?
    Penrith BC
    how do i know? i have all these bits going together as we speak (4.88 hilux G C+P into jzx90 carrier), and then im grafting the whole jzx90 pumpkin into the jza80 rear x-member
    ../delete/ban
    tech moderator
  9. #129
    Penrith BC
    ../delete/ban
    tech moderator
  10. #130
    bugger, this is wack
    Check the ratio in the local 4litre v6 hilux
    Jealousy is a curse
  12. #132
    I know this thread is mainly refering to the IRS diff centres but since there has been a little bit f talk aboutthe hilux gears.
    In my TA22 I have an early series ARB air locker centre designed for the older G series hilux diffs and it has the A series 3.7 diff gears bough new from toyota as fitted to a 1999 rwd Auto Hilux.
    In the RA28 I have the complete LSD centre, also an A series 3.7 from a 2007 3.0L turbo diesel hilux. Both are 8" G series equivilent although I did not count the bolts on the 2007 crown wheel as I fitted the entire centre.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  13. #133
    vic
    Hilux A is the same as old G , even the new ones .
    Trouble with all hilux stuff after about 2000 it was made in thailand and from past experiance diffs arnt as good as the earlyer ones.
    Dave
  14. #134
    Just to add something to the mix - the IS-F appears to use the Supra/Soarer/Aristo "A" series, and is 2.94:1
  15. #135
    alrighty just found out something interesting for those of us wanting short ratios in the so-called "A" series - looks like the US Lexus SC300 used a 4.27...
    http://www.clublexus.com/forums/show...7&postcount=53
    as you can see from my table in the previous post, thats an 11T pinion, 47T crown which is confirmed in that pic
    /me jumps onto eBay....
    By The Witzl in forum FAQ
  2. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 01:58 PM
