Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 93
Thread: MX83 Lowering Options
    vic
    Default Re: MX83 Lowering Options
    Unfortunatly im just realising all this now , I have the standard replacment MX83 KYB,s all round and notice it bottems over speed humps . But it is a smooth ride other than speed humps .
    Dave
    Oct 2007
    My front shocks have died so I have decided to use rav4. What is the part number for the KYB fonts?
    Quote Originally Posted by Huz
    Part number for the Rav4 inserts is 365-093.
    These inserts are shorter and you will need to put a 7mm spacer under the foot of the insert to use these but its easy. Any suspension shop can help you out and I believe they are called strut washers or shock washers in the trade.
    Nov 2007
    Just wondering does the lowered springs come in different sizes. ie can lower your car 1.5 inch or 2.5 inch? or is it just one size/type?
    I'm just gathering info at the moment.
    Thanks for posting up the KYB shock part codes.
    Front: Rav4 - 365-093
    Rear: MA70 Supra - 341-070
    Looks like it is a fairly simple job to do at home.
    Junior Member Domestic Engineer Viper's Avatar
    Lovells are the only ones that can be 'custom' height AFAIK.
    Rest are set.
    Daily: '06 Liberty 3.0R specB
    Project Car : '84 MA61: 2JZ-GTE + 6 Speed
    Nov 2007
    Sorry my bad. In my above post I was referring to King Springs which I had left out.
    Thanks Viper you have covered what I needed to know. You car looks like the height I want too
    Hm, sounds like ill be giving a few places a ring about the KYB shocks then.
    You guys just using ExcelG?
    I think they were called KYB- GR2.
    Kmac make custom height springs but quality of fit is a bit iffy.
    I would just by kings if I had to do it again.
    Nov 2007
    Are there any difficulties putting the KYB Rav4 shocks and King Spring in apart from using a 7mm shock spacer?
    I called Repco at St Peters NSW and got some prices:
    King Spring MX83 Lowered Front - KTFL-76 > $170
    King Spring MX83 Lowered Rear - KTRL-77 > $170
    KYB Shocks MA70 Supra - 341-070 > $175
    They didn't have the Rav4 on the system
    Also BA Falcon Rotors:
    Standard $85 Each
    4000 Series $141 Each
    Ah, you have to love Ripco prices.
    Try Bursons
    Usually much cheaper
    Raastler Grease Monkey
    For me personally I have gone through the troubles of purchasing springs and shocks and the rest of it to find that its not exactly what I want. I really think a set of JZX81 coilovers is the best way, you can adjust hte height to anything you want, you also have some camber adjustment in the front, if the sprigns that come with it are too hard you could possibly get replacements easier and cheaper cause they are a set ID/OD coilover and are easily available in many Kg/Lb ratings. You also have a good dampening setting and can possible get a brand that has dampener adjustable.
    Just my 2c. Coilovers can be made to be driven on the street.
    The prices i got were HUGELY different from the ones which MRZ got.
    Close to $450 for the set of 4.
    EDIT: didnt notice that his prices were for springs. Mine were for the shocks only.
    Cheapest prices I found;
    King Springs ~$110 front/rear set
    Ma70 Rear Shocks ~ $155 each
    MX83 Front Shocks ~$120 each
    Total : $670
    How much would the total coil-over setup cost? $1500?
    Oct 2007
    Matt-AE86: I assume your Mark 2 has similar suspension as Cressidas and you are realizing how much of a bitch it is to deal with. When I went to Pedders to get a quote for just springs and installation it was $690 and then I had the guy tell me that its because cressidas are not a good car to do up
    Viper: Where did you get your springs from that seems to be very cheap even for a trade price, I think that the rrp for kings is about $350
    I paid
    Front shocks $180 pair
    Rear shocks $210 pair
    Best price I have had for kings is $220 for the set of four.
    Just go to ebay, search for king springs or kybs and then email the seller for a quote.
    Try a few sellers and then choose the best. Just make sure they have good feedback and buy with paypal.
  1. Lowering an MX83
    By orestes in forum Tech and Conversions
    Last Post: 08-12-2007, 11:47 PM
  2. 1jz Jzx81 -> Mx83 Abs
    By mamba in forum Tech and Conversions
    Last Post: 21-11-2007, 08:28 PM
  3. MX83 lsd diff ratio options??
    By amichie in forum Tech and Conversions
    Last Post: 14-09-2007, 12:24 PM
