Page 52 of 85 FirstFirst ... 242505152535462 ... LastLast
Results 766 to 780 of 1266
Thread: 3T GTE Tech
  1. #766
    Default Re: 3T GTE Tech
    Haha, ignition is only going to be one element of the tune!
    The fuel map will need to be setup properly and since I read in another post your LM1 took a leave of absence I think that puts you behind the 8-ball immediatly.
    Don't give up on the low compression too quickly it sounds like you are simply needing to spend a little more time and the results will follow.
    Just a couple of things to check. Is the polarity of the magnetic sensor input for either/or sync and cam sensor out (don't know if you have sequential injection or not...). I find the engine will start and run with wires wrong but runs like a dog and if checked with timing light you find the timing advancing or retarding with rpm all by itself with the timing supposedly locked static. The ECU also needs to be informed of the correct sensor polarity i.e. rising or falling (positive or negative). Also the trigger signal to the ignitor - assuming external ignitor - ineeds to be set to the correct dwell and firing edge.
    I drove 7.0:1 compression happily to Dubbo and home again for a 2400KM round trip and it is my daily commute to work and back in the traffic! When you are pushing in excess of 20psi boost on pump fuel you will not regret low compression.
    Jason
  2. #767
    Not known unless ur blown Backyard Mechanic
    May 2007
    The cyl sync is fine, steady as at 54% which is more than acceptable for my ecu. I think the injectors not having a profile on my ecu will have a mass thing to do with it, I've set them to generic medium for opening times of .08ms or should i set to slow of .12ms ? Yea no doubt 7:1 is fine once on boost but driving it daily would mean driving above 3k all the time yea? that doesn't sound ideal. The motor revs happily out to 7g but its just once on load it doesn't act the same just sluggish and gutless. Highly considering leaving it till I can afford to put in higher comp pistons. O2 sensors arnt that important if u get a tune on a dyno im guessing they have all the right probes n shit there.
  3. #768
    No issue here with low rpm driving around. With the nice small GT2560 and .64AR turbing housing I used 40 degrees initial timing and all was well cos it used to be on boost by 1800rpm at partial throttle. Once the S200sx with 1.00AR turbine went on it was a little doughey and I fed it another 5 degrees timing off boost and driveability has come back up again nicely - along with some minor tweaking of the fuel curve of course. I can slide the clutch from idle and outpace most of the traffic off boost on part throttle while making the decision as to whether to nail it wide open and risk a conversation with Mr Plod...
    Jason
  4. #769
    Jun 2011
    Tasmania
    Find Cheap Used & Second Hand Cars For Sale | North Hobart | Gumtree Classifieds
    seriously check this clean as a whistle example of old school celica!!!
    Not just another toy, My pride, My joy!
  5. #770
    Jun 2010
    thanks roger thats awesome to know the 1ggte auto will bolt up and haves sorced one now to find a place in brissy to build the bugger haha
  6. #771
    Feb 2011
    south australia
    hey i used to own a red tt142 corona with 3tgte and that was factory auto push button 4speed overdrive. it was in awsome nic. but i cant find it as i want that car back it had done 39,000 ks and i baught it off of al palmer in penrith but where it is now i have no idea. if anyone know who has it let me know pm me cheers
    1985 ST141 TOYOTA CORONA SR 5SP MANUAL 2S-C
    1985 RT142 TOYOTA CORONA SR 5 SP MANUAL 22R-E
    1986 RT142 TOYOTA CORONA WAGON 5SP MANUAL 22R-E
    1984 TT142 TOYOTA CORONA GT-T 5SP MANUAL 3T-GTE
    1983 AT141 TOYOTA CORONA GT 5SP MANUAL 4AGE
  7. #772
    Feb 2011
    south australia
    Anyone know where i can get a 3tgte exhaust manifold gasket???? I need one asap please!!!!!!!
  8. #773
    Hey the 3tgte exhaust manifold will take the same design as the 2t or 3t - I just cant tell if the material will be the same.
    I simply use silicon like grey max or such as long as the sealing surfaces are relatively flat. Not too much of course as you dont want it bulging out into the inside of the manifold and turning into turbo destroying missiles...
    Jason
  9. #774
    Jul 2009
    stewart wilkins motorsport got em for $19:
    SW Motorsport
    It's for 2TG but should fit. Stewart Wilkins are good for various 3T/2T parts, i've bought quite a bit from them and have always been reliable.
    my old ride:
  10. #775
    Jun 2011
    Tasmania
    Quote Originally Posted by steeko View Post
    SW Motorsport
    where in Aussie are SW??? as im in tassie.
  11. #776
    Jul 2009
    They're in NSW. Freight price is reasonable too.
    Unit 6
    16 Wingate Road
    Mulgrave NSW 2756
    my old ride:
  12. #777
    Jun 2011
    Tasmania
    Unit 6
    16 Wingate Road
    Mulgrave NSW 2756
    sweet cheers
  13. #778
    Feb 2011
    south australia
    cheers they should get me outa trouble.
  14. #779
    Jun 2011
    Tasmania
    where can i get a heavy duty single plate clutch for my 3tgte and how much?? to suit w58 box??
  15. #780
    Hey guys I really need to start thinking about a head gasket, as it has forged pistons do I have to get a particular thickness?
    Nath
    -Just Alloy Radiators-
    www.alloyradiators.com.au
  1. 3T Versus 3T GTE conrods
    Last Post: 01-06-2007, 12:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
