Page 51 of 85 FirstFirst ... 41495051525361 ... LastLast
Results 751 to 765 of 1266
Thread: 3T GTE Tech
  1. #751
    nuts Grease Monkey
    auckland
    Default Re: 3T GTE Tech
    Quote Originally Posted by 3sgte View Post
    I thought stock is 88 degrees C?
    GT Corona Turbo, here's the part number:
    ToyoDIY.com
    ok maybe, but all the ones i've pulled out have 82'C written on them. the fully open temperature i don't believe is the temperature it starts opening at? If you live in a cold climate like up in norway/finland/canada etc then higher rating usually used. Can't see why someone in hot australia would use a hotter thermostat? feel free to converse on this, it'd be interesting to know.
    3tgte engine wiring diagram is not hard to find. google it and click images.
    some here i've mirrored. http://www.toycrazy.net/tech/3tgte.htm
    member '3sgte' may have a genuine one?
    -Mark
    E2 + E7 fan
  2. #752
    Canada
    Not in English, and it is still just a scan anyhow.
  3. #753
    nuts Grease Monkey
    auckland
    YES PLEASE! it would be the first genuine wiring diagram available online to westerners. im yet to get that 2t/3t/2tg book scanned sorry
    -Mark
    E2 + E7 fan
  4. #754
    Canada
    It looks basically like the one you have on your site, but with slightly better quality.
  5. #755
    Jun 2011
    Tasmania
    is it me or ??
    i cant see a link.... desperately need a diagram, google isnt helping
    Not just another toy, My pride, My joy!
  6. #756
    Canada
    They are halfway down the page.
    Here is a link for one of the 5 pages:
    http://www.toycrazy.net/tech/pics/3t...ngdiagram1.gif
    EDIT:
    Did you find it?
    (PM sent)
  7. #757
    Feb 2011
    south australia
    anyone here know where i can get spark plug leads for the 3tgte????
    1985 ST141 TOYOTA CORONA SR 5SP MANUAL 2S-C
    1985 RT142 TOYOTA CORONA SR 5 SP MANUAL 22R-E
    1986 RT142 TOYOTA CORONA WAGON 5SP MANUAL 22R-E
    1984 TT142 TOYOTA CORONA GT-T 5SP MANUAL 3T-GTE
    1983 AT141 TOYOTA CORONA GT 5SP MANUAL 4AGE
  8. #758
    New Zealand
    Keep your original boots and replace the leads in them using a cheap V8 set.
    Callum
  9. #759
    Canada
    Quote Originally Posted by gt-t corona turbo View Post
    http://www.toymods.org.au/forums/tec...ml#post1345532
    They are generally available through yahoo auction for about 30% off list price. (Plus whatever the auction exporter requires.)
  10. #760
    Jun 2010
    hey guys names phil
    had a 3tgte kicking round for about 6 months now trying to decided what to jam it in
    thought about the whole 7m injectors and 5m afm and trying to squeez every kw out of the stock comp but f that
    so ive decided to go stand alone with waisted spark setup
    with a fairly oversized turbo and built auto to get her up on boost and keep her there
    its goin to be goin it my ke20 so should be quite the handfull
    basicaly im wondering if anyone is using a built auto behind one what are u using?
    if not does anyone know of a good box that is easily built to handle around the 400hp mark
    im gonna throw a fair bit of money at this thing and have no intentions of getting it done in a month hell il be glad to drive it by next christmas
    so anyone goin auto and big turbo combo?
  11. #761
    phil-ma70
    have not herd of it done, the 3tgte did come out with an auto I belive. How about an auto from a 1ggte or 1gge the bolt pattern on the block is the same as the 3tgte (i.e. 1g bell housing fits a 3tgte).
    Roger
  12. #762
    Not known unless ur blown Backyard Mechanic
    May 2007
    Just putting a CALL out for a 3tgte ign and fuel map to suit low compression pistons. (7:1~7.5:1).. My motor idles fairly well with the exhaust manifold fixed up, its just still gutless and not getting a decent power band. Turned off the O2 sensor bcuz the LC1 shit it self and wouldnt heat up my sensor so bad readings. Ideally im after a manifold pressure map or even a manifold pressure vs tps. and yea ign map. 3jcelica was kind enough to send me his, but it only allows for it to run roughly. This is only a temp and I'll put it on a dyno soon but if I can just get it running a little nicer that would be awesome.
    I've set the injectors on the ECU to generic medium opening speed of .08ms and I'm running full sequential fuel and ign. So yea if anyone can help thanks in advance.!
  13. #763
    Hey there Radar,
    I am assuming you have a programmable ECU there.
    Straight up I know nothing about programming fuel injection... I run carbs...
    Ignition on a 7:1 compression engine however is right down my line! Give it something under 20 degrees initial for cranking over and bump it straight up to around 35 (or over) degrees right from idle to 0psi (onset of boost). Currently I have two 7 to 1 compression engines and both are running around 45 degrees initial up until the onset of boost.
    If you try to run a low comp engine on a 'normal' ignition map it will be gutless and much less than a pleasure to drive.
    Jason
  14. #764
    Jun 2010
    whats the difference with 7mgte and 1ggte auto boxes anything??
  15. #765
    May 2007
    Are you talking after TDC or before TDC? If it's before wouldnt that just be making the motor detonate?(well have similar charataristics as detonation?)
    EDIT**
    Tried with 45degrees timing, still is popping and idle doesnt really change. Very much over this low compression crap!
  1. 3T Versus 3T GTE conrods
    Last Post: 01-06-2007, 12:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
