Page 53 of 85 FirstFirst ... 343515253545563 ... LastLast
Results 781 to 795 of 1266
Thread: 3T GTE Tech
  1. #781
    Default Re: 3T GTE Tech
    depends on your engine, how much has your head/block been machined, head cc, piston crown height and desired compression ratio. Also some T series head gaskets are just made to 80mm bore and this will need to be factored in.
  2. #782
    Jun 2011
    Tasmania
    k guys got the ct26 twin scroll with custom manifold on, about to install some 550cc s5 rx7 injectors, maybe 800cc hks if the price is right, then hit the tuner up to see if my microtech will handle it! woo cant wait... 3tgte all the way
    Not just another toy, My pride, My joy!
  3. #783
    Quote Originally Posted by RiceburnaGTV View Post
    Hey guys I really need to start thinking about a head gasket, as it has forged pistons do I have to get a particular thickness?
    Nath
    Gasket thickness is based upon the clearance from piston to head. Some engines that I've done have the pistons "out of the hole", because they've been decked a lot (previously). I like to run them from 1.25mm (std), down to about 0.75mm (NOTE: that's clearance, NOT HG thickness).
  4. #784
    Feb 2011
    south australia
    hey im thinking of changing the intake on my 3tgte but the only problem is my dizzy will be in the way unless theres a way around it. has anyone have any ideas how i could do this?? id like the intake to face forwards to the engine insted of across the engine.
    1985 ST141 TOYOTA CORONA SR 5SP MANUAL 2S-C
    1985 RT142 TOYOTA CORONA SR 5 SP MANUAL 22R-E
    1986 RT142 TOYOTA CORONA WAGON 5SP MANUAL 22R-E
    1984 TT142 TOYOTA CORONA GT-T 5SP MANUAL 3T-GTE
    1983 AT141 TOYOTA CORONA GT 5SP MANUAL 4AGE
  5. #785
    Get good engine management, remove the dizzy and run coil packs. Face the T/B forward and enjoy.
  6. #786
    Feb 2011
    south australia
    what do you call good engine management?? brands and so on what coil packs should i run?? can i adapt a 22r-e intake to it??
  7. #787
    good engine management = one that does what you want it to do and one that your tuner wants to use. What you want if fuel, spark and the ability to run coil packs (which I think ALL of the regular aftermarket computers do), sequential injection would also be nice.
    Email me. [email protected]
  8. #788
    Jun 2011
    Tasmania
    autronic sm4 would have to be my pick, but im currently running a microtech atm that isnt bad either...
    that image should let your imagination run wild, sourced from google images
  9. #789
    Jun 2011
    Tasmania
    just curious guys, what sort of mods are you all running in your 3TGTE's and what sort of power out-puts??
  10. #790
    Feb 2011
    south australia
    Quote Originally Posted by spaz021 View Post
    that gives me some idea what to do. but i only have limmited room in my tt142 corona so woking how much room i have left and to fit it will be a challange.
  11. #791
    Canada
    Have you checked here:
    http://www.toymods.org.au/forums/dyn...-variants.html
  12. #792
    Texas,USA
    I run an Haltech e6x on mine. I agree get rid of the dizzy.
    ae-86 (levin) footwork
    TE-71 w/1uzfe
    Autronics SM4
  13. #793
    Quote Originally Posted by turbotoy View Post
    I run the same ECU as turbotoy. Not too bad considering I was able to resuse all my existing haltech bits... Picture of my Plenum as follows:
    I run the haltech halleffect sensor with a modified dizzy base that holds a custom made wheel which holds the rare earth magnets.. Nothing overly complex but required a bit of planning.
    definitely do away with standard dizzy...
    See my 3T-GTE powered TA22:
    Click Here
    Currently running 192.8rwkw @ 20PSI
  14. #794
    Texas,USA
    Looking good. This motor relay responds to new intake and exhaust manifolds. I didn't go the modified stock dizzy because I always knew cams were going to be different then factory. I had to use crank sensor and cam lobe sensor.
    TE-71 w/1uzfe
    Autronics SM4
  15. #795
    Not known unless ur blown Backyard Mechanic
    May 2007
    Just putting a call out again for a Fuel/Ign Map for a low comp 3TGTE with std injectors. Anyone got something decent? Mine idles and revs alright but could be 10x better. Massivly appreciated if anyone can help.
  1. 3T Versus 3T GTE conrods
    Last Post: 01-06-2007, 12:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
