Page 26 of 139 FirstFirst ... 1624252627283676126 ... LastLast
Results 376 to 390 of 2085
  1. #376
    is damn glad to meet ya. Domestic Engineer andy's Avatar
    the bog/primer was used on my petrol tank(on the motor bike), so yes, i hope it dosnt cause rust and contamination of the fuel.
    you can do anything at http://www.zombo.com/
    the only limitation is yourself
  2. #377
    Just read the $50.00 paint job in its entirety. For the time involved in recoating and recoating and recoating, and recoating, on top of the prep time, I say forget it.
    I can buy enough primer and colour to do a reasonable size car for under $300.00. The prep time will be the same as for any paint job.
    Once prepped the spraying only takes an hour or 2, and then you can put your car back together the next day.
    $50.00 roller paintjob is cost effective, but
    a spray job will be way more time effective.
    cheers Chuck.
    MS51Crown Coupe,
  3. #378
    Chuck... the other part of it is the air compressor and spray gun. People on here are talking about $400+ for a decent gun... and you are looking at a minimum of $900 for a decent air compressor. Well worth it if you are using them for a multitude of projects (I have had heaps of use from my compressors and spray guns over the years), but not so effective if your a poor uni student with $50 in his pocket, and in need of a paint job.
    Also, an improvement on his method is to use a slow drying enamel based paint. Roll it on with a foam roller, wait 15 mins, roll it again, wait another 15 and roll it, keep doing that until it is firm. This will eliminate a lot of the need for cutting it back.
  4. #379
    HP Guru Backyard Mechanic driftedmz20's Avatar
    Jan 2008
    from everyones experience whos good in NSW for a full spray job at a reasonable price?
    including prep work off course and NO engine bay
    have 2 cars that im chasing to get done
  5. #380
    vic
    I have the same question in Vic , what good eastern suburbs panel shops are there .
    Also im finally painting a mark2 that i have owned for 10 years , it has a few prior repair spots that need to redone but there is a few layers of paint in other repaired spots that still look good.
    Will any problems suface later on after a 2pac respray over 20 year old acrylic or maybe enamal paint that is still in good condition .
    Also i plan to fiberglass a couple of tiny pinholes of rust , by using por15 first then fiberglass over it . ?????
    Dave
  6. #381
    I just want to paint my calipers, looks like I got some reading to do in this thread
  7. #382
    Jan 2008
    Quote Originally Posted by RObErT_RaTh
    what car you have.. i have a set of MZ20 calipers painted in GOLD that have never been on the car that i need to get rid of.
    anyway painting calipers is easy make sure you give them a good clean first and cover over the sliders etc so they dont get paint on them
    ill take some pics of mine a bit later and upload so you can what i did and what it looks like
    Removed pics as no longer needed!
  8. #383
    Jan 2008
    wooooaahhhhhhh maybe should of reduced those lol
  9. #384
    Yeh, I got a 1600x1200 res monitor and they don't fit on my screen
    I've got a set of Z32 nissan brakes that I'll be painting and upgrading to so I don't think the soarer brakes will help me, sorry. And I wouldn't have gold ones on my car anyway, painting them black
  10. #385
    Jan 2008
    lol they dont fit on my 22in either hahaha
    nah its cool was just so that you could see
    just make sure on the nissan brakes when you paint you cover over the top etc and only paint the face etc and youll be sweet
  11. #386
    lol, 10 megabit camera?
    id be reducing them and trying again mate.
  12. #387
    Jan 2008
    a megabit camera? lol dont you mean megapixel cobba?
  13. #388
    Quote Originally Posted by driftedmz20
    Well the calipers are currently pulled apart and main parts are in 2 pieces and pistons and seals are out etc so I'll be masking off the important workings and just spraying the outer bits Bought some primer and gloss black yesterday so just gotta prep the surface and hope for a warm day next weekend.
  14. #389
    Are you planning to use your brakes? If so be careful about what you paint the calipers with, they suffer some pretty hefty heat after hard application.
  15. #390
    Jan 2008
    lol yeah must be heat paint and not normal otherwise will just flake off
    Last Post: 06-01-2010, 08:34 PM
    Last Post: 22-09-2007, 11:52 PM
    Last Post: 11-01-2006, 09:53 AM
