Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 91 to 105 of 149
Thread: Brake Upgrade - XT130/RT132 Strut with Nissan Alloy Caliper - Research Stage
  1. #91
    Forum Sponsor Conversion King
    Default Re: Brake Upgrade - XT130/RT132 Strut with Nissan Alloy Caliper - Research Stage
    nah it shouldnt be too bad, as the xt130 hubs have quite an offset, pushing the wheel out, so may only just need a small spacer, and LONGER studs ;p....ie the hubs sit far forward off the disc.....
    blake
    considering thats what i had on the rolla i know they fit.
    may need a 3mm spacer but that would be max.
    linden
    ps check my avatar.
  2. #92
    and they fit over the r33 setup?
  3. #93
    New Zealand
    If you are using matched R33 calipers and R33 discs then isn't the wheel fitment same as an R33? Easiest way to test wheels BEFORE you buy them.
    Callum
  4. #94
    Quote Originally Posted by WDE_BDY
    Callum
    alas the 33 is 5 stud and would require a 25mm 5-4 stud adapter to give it the same pattern and offset of the disc as what this setup is so short answer NO.
    linden
  5. #95
    New Zealand
    Ah yes, forgot the 4 to 5 stud issues (both my cars have been converted to 5 stud). Caliper clearance will be the same though won't it?
    Callum
    EDIT: Ignore me, brain fade.
    Went and looked again and realised rotors are now rear mounted so heaps more caliper clearance. Had myself confused as you mentioned you try to keep rotor/caliper from same Skyline model so can upgrade easily with same brackets.
  6. #96
    linden
    ps check my avatar.
    That 3mm would be fixed with an RT132 hub instead of the XT130 hub, as there's about 4mm difference (off the top of my head) between the two...
    ([][][]II--LT--II[][][])
  7. #97
    just an update on this.
    i finally got the brackets for the r32 stuff back on fri and this time they measured correctly.
    everything bolts up sweet (thank christ).
    got absolutely flogged for the brackets though so this wont be a cheap ugrade but probly the best thing you could fit behind 15" simmons.
    linden
    ps i dont know how to put up pics but if someone can pm me a moby no. i can send pics to them to upload.
  8. #98
    linden
    I'll come down with a camera later and do it so should have pics up tonight
  9. #99
    silly bum had me there all Sunday and didnt ask for pics
    Black Betty >HERE!<
    (\__/)
  10. #100
    Quote Originally Posted by TA-022
    i figured you where struggling enough with rewiring you fuel pumps
  11. #101
    thats harsh dude
    i wont replace that 6pack now
    Its a tidy looking setup now with the bracket all nice and finished.
    Black Betty >HERE!<
    (\__/)
  12. #102
    just jokes nath.
    can anyone confirm the diffence between the xt130 and rt130/2 hubs being different offsets and by how much.
    linden
  13. #103
    pm takai he did a massive thread for the hilux pug upgrade
    from memory its was like 3 or 5mm though
  14. #104
    3-4mm .. i measured at pickies when this was discovered.
    its in the original thread.
    xt130 requires wheels with a bit off meat on the mounting surface as the caliper siter proud 3-4mm.
    RTXXX has the hub inline with the highest point of the caliper so flat wheels work.
    curving back spokes are an issue depending on wheel diameter.
    put it this way .. hilux/pug and 14inch celica steelies .. dont work by about 2-3mm due to curve backwards design in the spokes.
    Black Betty >HERE!<
    (\__/)
  15. #105
    damn simmons wheels.
    with the disc 3mm of the lca there needs to be a 3mm spacer in there for the calipers to clear the bolts (3 piece).
    but ill go to pickies tommorrow with verniers to check the difference (dont like spacers that aren't bolt on)
    for anyone interested in doing this with simmons ill put up all the measurements for the parts that need to be machined to do this upgrade.
    oh ssr's clear no worries at all.
    linden
  1. R32 Nissan rear brake caliper
    Last Post: 31-12-2014, 10:58 AM
  2. mx83 brake upgrade; my pics
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 04-02-2011, 09:21 AM
  3. Toyota equivalent for Ryco Z145a Oil filter
    By optionUP in forum Tech and Conversions
    Last Post: 02-09-2009, 11:04 AM
  4. AE86 Brake Upgrade - Nissan style
    By CrUZida in forum Tech and Conversions
    Last Post: 15-10-2006, 07:13 AM
  5. break upgrades/ta23
    By buztoy in forum Tech and Conversions
    Last Post: 14-10-2006, 08:00 PM
