Page 8 of 10 FirstFirst ... 678910 LastLast
Results 106 to 120 of 149
Thread: Brake Upgrade - XT130/RT132 Strut with Nissan Alloy Caliper - Research Stage
  1. #106
    Default Re: Brake Upgrade - XT130/RT132 Strut with Nissan Alloy Caliper - Research Stage
    do the 15" SSR mesh clear the R33 setup tho?
  2. #107
    Forum Sponsor Conversion King
    Threw the 15" ssr's both LeeRoys and mine and theyre the same. The caliper hits on the wheel about 2" from the center of the 3 piece on the inner rim. The wheel actually steps up about 1" inward for the wheel trough and about 1" further inwards is where the caliper makes contact by approx 1mm but its enough to make the wheel not turn when bolted up.
    The caliper makes contact right at the join of the two halves and only just makes contact. The marks where it was rubbing went along this line and were only about 3mm wide.
    If you had a rim that was near negative offset then it probably wont hit as mine didnt when i had the other wheels on the front of the rolla. Either way its something that would need to be checked beforehand.
    To overcome the problems here you could probably linish the caliper down by a few mm without any dramas but it would depend on your wheels. On the ssr's we put on there you would need 1" spacers or larger to get clearance but otherwise the spacers are not an option. Taking a bit of meat of the caliper should pose no dramas but this is something that needs to be done carefully and with as little as possible removed.
    If we were making new brackets another option would be to move the caliper closer to the hub by the 3 or so mm required for clearance and then take a few mm off the diameter of the rotor.
    The camera has died in the arse but picsof everything tomorrow hopefully.
    linden
  3. #108
    AWSOME job, thanks linden!!!!!!!!
  4. #109
  5. #110
    And heres the larger calipers and where they were scrubbing. The mark closest to the camera was where the caliper was scrubbing. The second mark is where the ssr's off Lindens rolla stepped up and where other wheels would need to step up in order to clear
  6. #111
    Well RTXXX hubs will solve the 3piece nut scrape issues +3mm easily.
    Sif you can get your arse down to pickies
    Black Betty >HERE!<
    (\__/)
  7. #112
    Im pretty sure there is none down there atm however i really need some aswell!
  8. #113
    good job leeroy!
    there looking very sweet.
    probably a goo idea to stick with a 16" rim, as if i buckle a rim at the track it will most likely take out the caliper aswell, good to have SOME clearance
    cheers,. blake
  9. #114
    So did you find some rt132 hubs linden?
    tested them yet?
  10. #115
    nope but fixed it another way, more machining but got it sorted.
    its something ill have to keep in mind for any simmons but pretty much all jap rims will be sweet.
    linden
  11. #116
    S.A
    Out of interest..... Who made the caliper brackets ?
  12. #117
    The man 1 post above your's...
    ([][][]II--LT--II[][][])
  13. #118
    He designed them but outsourced the machine work
  14. #119
    a mob near me. dont bother ringing cause i cant understand him in person.
    prime tooling in kings park nsw.
    expensive but good work
    linden
  15. #120
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    subscribe. this should be good
  1. R32 Nissan rear brake caliper
    Last Post: 31-12-2014, 10:58 AM
  2. mx83 brake upgrade; my pics
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 04-02-2011, 09:21 AM
  3. Toyota equivalent for Ryco Z145a Oil filter
    By optionUP in forum Tech and Conversions
    Last Post: 02-09-2009, 11:04 AM
  4. AE86 Brake Upgrade - Nissan style
    By CrUZida in forum Tech and Conversions
    Last Post: 15-10-2006, 07:13 AM
  5. break upgrades/ta23
    By buztoy in forum Tech and Conversions
    Last Post: 14-10-2006, 08:00 PM
