Results 1 to 6 of 6
Thread: 3RZ-FE pinouts
    User Conversion King
    NWA
    Default 3RZ-FE pinouts
    had a few minutes while watching TV and a ECU spare so ive documented the pinouts.
    this ecu was from a 1998' prado. with a manual W56 gearbox.
    part number is TOYOTA: 89661-60370 & DENSO 175000-8801. M/T
    the diagram is looking straight at the ECU
    the plugs are 26PIN 16PIN 12PIN 22PIN.
    the 22PIN plug connects to the dash loom and the other 3 go to the engine directly.
    its interesting to note its a "M/T" ecu yet there is pin like PWR, 2, L, S1, S2, SL. unless the pins are there and the hardware isnt on the board.
    i wonder why the ECU wants to know the car is in 4WD?
    hello
    wa
    Default Re: 3RZ-FE pinouts
    i think the ecu controls the 4wd light on dash
    NWA
    and for searching purposes:
    3RZ 3RZFE 3RZ-FE pinouts ECU pins loom plugs
    hello
    interesting to note that it's only got2 injector channels - so it's probably squirting in much the same way as the 4age or 4agze does
    Also - what kind of idle control does it have? PWM valve?
    Digging up this oldie.....
    Just doing a 3rz-fe Pin out chart for a '99 4x4 and need help with some of the abbreviations in the ECU.
    What is??
    OXO (Could be OX0 'zero'.....0X2 is Oxygen Sensor...)
    TFN
    CASE ( Cam Angle Sensor?? What's the 'E' for?)
    VAF
    IMI ( Could be IM1)
    IMO ( Could be IM0 'zero')
    If G2 is Camshaft Position...What is Cam angle (as in CAS) Are they Different??
    Forgive me if some of the answers here are common knowledge....but I wasn't raised in the era of Computers.
    1g-gze Corona RT132 (Daily)
    RA23 Celica (Project under way)
    RT81 & MS112 (Still Thinking About It!)
    Wife thinks i'm mad (yep... she's right!)
    JDM cressida luv 1st year Apprentice
    Nov 2009
    Quote Originally Posted by brett_celicacoupe View Post
    Do you still have the linked picture above by any chance?
    I'm chasing down any wiring info I can find for a 3rz conversion I'll be doing soon.
  1. ECU pinouts Gen 3 1GGZE (Definitive?)
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 24-09-2017, 10:29 PM
  2. need 3sge ECU pinouts
    By EldarO in forum Tech and Conversions
    Last Post: 03-04-2007, 07:34 PM
  3. alternator plug pinouts
    By StuC in forum Tech and Conversions
    Last Post: 21-03-2007, 04:51 PM
  4. Gen3 Pinouts
    By mikie in forum Tech and Conversions
    Last Post: 10-08-2006, 08:18 AM
  5. How to connect switches to switched pinouts on a toyota ECU?
    By 2JZR31 in forum Tech and Conversions
    Last Post: 31-03-2006, 03:04 PM
