Results 1 to 5 of 5
Thread: Gen3 Pinouts
    I like Stuff Backyard Mechanic mikie's Avatar
    Default Gen3 Pinouts
    this will most likely turn out to be a stupid question, but i am really unsure and need this clarified.
    does the gen3 3sge and 3sgte use the same ecu, does any one have the gen3 3sge pinouts. i have the 3sgte but can't find the 3sge. i know that the loom and ecu was upgraded every version, but did they run different ecu in the turbo compared to the n/a.
    if the ecu is different would the pin outs be similar.
    cheers Mike
    if any one wants gen3 turbo pin outs, let me know.
    Default Re: Gen3 Pinouts
    Quote Originally Posted by mikie
    answer that^^ HELL NO
    i don't have the gen3 3sge pinouts, but AndyTTR from the st162 dedicated thread may be able to help, he put a gen3 in his 162, he may still have the pinouts, or know where you can get them
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    would a gte ecu run a ge if correctly rewired?????
    how different is the engine loom between the ge and gte.
    obviously the intercooler temp sensors and ascociated.
    what adout waste gate actuator, elecrtonic or mechanical???
    cheers Mike
    it *may* run it if wired correctly, but it would more than likely run like shit if it did at all, the a/f mapping and timing would be way off for an na motor. plus because of the missing turbo sensors it would run in limp mode all the time,
    find your self a ge ecu, i am sure they are at importers
    89' MR2 AW11... His
    im trying to find aftermarket management for a supercharged 3sge, but all i can find in plug and play is for the gte. guess i will need to fork over $$$ down the track and spend a lot of time boozy.
    Mike
  1. 5m-e pinouts
    By regin in forum Tech and Conversions
    Last Post: 28-05-2006, 11:13 AM
  2. Oil pipe on gen3 3sgte head
    Last Post: 31-10-2005, 02:08 PM
  3. FAQ: 3SGTE Gen3 / Gen2 Differences
    By Toobs in forum Tech and Conversions
    Last Post: 10-10-2005, 04:32 PM
