Results 1 to 4 of 4
Thread: alternator plug pinouts
    Default alternator plug pinouts
    Running a gen2 3sge in st162 with microtech, but has 2 pin plug on loo (st184/185 alternator previuosly fitted) and am now fitting an alternator from an st202 or beams engine which is 3 pin. I need the pinouts for both the 2pin plug and the 3 pin so i can just swap the wires to the 2 pins i need.
    Help much appreciated.
    Cheers, Stu
    oh, and i also the same goes for the starter so if someone has the wiring diagram for that and possibly even the starter motor plug i'd love it.
    Default Re: alternator plug pinouts
    use the alternator that fits your loom if you still have it, there all interchangable, well i know the 16x and 18x varieties were.
    the starter wire has a clip on the end of it not a plug as such should be easy to find. brown or black haha doesnt really help but you never know.
    2 pin plug sounds odd, someone has probably fitted a bosch unit to it at some point, you will need battery sense, ignition feed and warning light, it should have a little diagram on the alternator sticker with S, IG, L.
    Thanks guys - rep has been given
  1. ECU pinouts Gen 3 1GGZE (Definitive?)
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 24-09-2017, 11:29 PM
  2. 5VZ-FE Auto Pinouts & wiring Diagram wanted
    By TheToyman75 in forum Tech and Conversions
    Last Post: 27-02-2007, 05:04 PM
  3. Gen3 Pinouts
    By mikie in forum Tech and Conversions
    Last Post: 10-08-2006, 09:18 AM
  4. 5m-e pinouts
    By regin in forum Tech and Conversions
    Last Post: 28-05-2006, 11:13 AM
  5. How to connect switches to switched pinouts on a toyota ECU?
    By 2JZR31 in forum Tech and Conversions
    Last Post: 31-03-2006, 04:04 PM
