Page 29 of 392 FirstFirst ... 1927282930313979129 ... LastLast
Results 421 to 435 of 5875
  1. #421
    Forum Member Grease Monkey smokem1's Avatar
    Northern Territory
    Quote Originally Posted by jcmunga
    can anyone tell me how heavy an 18r motor is?
    Just spoke to Toyota:
    18R weighs 165kg. I couldnt see an 18RG weighing much more or less than this.
    PS ya's are probly aware but a lot of pics in this thread arent working anymore, same with some pics in Witzls Falcon EA alternator to 18RG swap thread.
  2. #422
    Wow, that's heavy.
    Any idea what's included as extras on that weight?
    We weighed the 18R-C we took out and the 18RG we put in.
    18R-C = 140kg
    18RG = 130kg
    While both engines were missing exhaust manifolds, it still shows that the 18RG is about 10kg lighter than the 18R-C.
    I think our scales would have been reasonably correct, the two of us would have had more trouble carrying it out from the store room if it was 155-165kg.
    (\__/)
    (")_(")
  3. #423
    Neither engine had A/C attached.
    (\__/)
    (")_(")
  4. #424
    Northern Territory
    Quoted 165kg, rocker cover to sump, no accessories attached eg exhast, manifold etc. yours were'nt bathroom scales were they? . I reckon your right about the 18RG weighing less though, got all the alloy goodness .
  5. #425
    Yup, 18R-C has an iron head so of course it's going to weigh a lot more.
  6. #426
    dry weight though? That could make a bit of difference
    also - the pictures missing are thanks to my old host going p00 and refusing me to log in and save the directory/file structure....
    ...... butt scratcher?!
  7. #427
    K Power Grease Monkey Damo82's Avatar
    Got my 18RG tuned and dynoed yesterday (still running in the engine). Hope the chart below will be a useful reference for anyone else in regards to tuning, expected power etc.
    Had a little bit of work done, bored out to 2.2L, balanced and blueprinted, mild port and polish, 40mm solexes, extractors, the usual.
  8. #428
    i really was expecting more from a 2.2L bore
    good work though .. few go the path
    props to you
    Black Betty >HERE!<
    (\__/)
  9. #429
    Have to admit I was expecting a bit more, but she's still running pretty much stock 18RGU compression. If I upped the compression a bit more it might help.
  10. #430
    What cams are you running?
    Did you get a full rejet tune or just an idle tune and a power run?
    Those fuel ratios look a bit lean in the upper end there, that might make some cause for power loss.
    (\__/)
    (")_(")
  11. #431
    Junior Member Domestic Engineer tricky's Avatar
    That's good power, and definitely a good base to start from. A set of cams and some bigger carbies (or quads) would see that jump up to about 95, but if the compression is too low, it would be a bitch to drive... Anyway, have some fun with the beast! You definitely deserve it after the stuff you've been through!
    Nikita the RA23 is almost finished .
  12. #432
    That's running 270 cams, I have some 230 cams but don't have the early cam gears for them which is why I am not using them at the moment.
    The carbies have just been rebuilt so I think he just did a power run and idle tune at a guess.
  13. #433
    Gosh! 270 cams would really be choking it a bit! Good for driveability, but with some earlier cams it'll scream!
  14. #434
    south australia
    didn't rt104gt mention that you can use a simple 18rc cam gear on the earlier cams?
    edit:
    Hmm Maybe not, this is what i remember reading
    http://www.toymods.net/forums/showthread.php?t=13207
  15. #435
    Sounds like I might need to look into finding a set of early cam gears then :-)
