# EDIT#
I measured the hole positions in an unreliable way,
*here are the latest, more reliable measurements*
I double checked, the hole spacing are not all the same, infact each cam gear is slightly different, BUGGER.
I checked four cogs this time.
The thickness of material between the holes varies This is what was measured this time.
The first two holes (clockwise from front) are 7.3 -7.35mm apart. (two of each)
The 2nd and 3rd holes are mostly 7.4mm apart. (one was 7.3mm)
The 3rd and 4th holes are 7.5-7.6mm apart. (two of each)
The second hole (clockwise from front) is displaced 4.12 degrees clockwise from the centre of the marked tooth.
Hole diameters are 6.15mm
Holes are 17.1mm from the centre of the cog.
Sorry about the mix up,
Witzl, are you able to get those cogs measured?
I'm not sure how the extra four holes would be spaced now.
