Page 353 of 392 FirstFirst ... 253303343351352353354355363 ... LastLast
Results 5,281 to 5,295 of 5875
  1. #5281
    Top End
    seriously are we talking the two little spring clips ?
    WOW
    just go to your local freindly mechanics or wreckers a ask beg steal borrow some
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  2. #5282
    The $84 was through some part mob in America, toyota can sell me a pair for $8 with a 3 day wait. Amayama wants $9 postage.
  3. #5283
    Jul 2011
    Saskatchewan, Canada
    I've put a gasket kit through the 45DCOEs on my 18R-GU, but have a couple of parts left over.
    Does anyone know what the 7 smaller o-rings are for in this gasket kit?
  4. #5284
    Eltham vic
    can anyone help me find the thread on changing the head gasket on an 18rg
    i have searched the suggested threads with no luck
    my main concern is getting it all back together correctly , in some other engines that i have worked on
    i could simply cable tie the cam gears to the chain , then it could only go back in the position
    that it came off but on my engine there doesn't seem to be any holes in the cam gear to pass a cable tie through
    after almost 15 years of racing the blue shitter blew the head gasket
    i have the green manual as a guide , but it is a bit vague , a bit like me i suppose
    thanks
    ian
  5. #5285
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    thanks
    ian
    Set the bottom end to tdc then theres some marks on the cam that should be facing upwards I think the lobes end up pointing away from each other
  6. #5286
    Jan 2012
    Finland
    Nothing couldn't be simpler:turn the timing mark to TDC.On the table put the head on some stands so it wouldn't be on the valves when the cam bearing caps are tightened.BEFORE tightening turn both cams so that the slot in cams is up! (this is a common time to bend valves..)
    Lower the head on the block and find correct holes in cam gears and cams so that when chain is tight the TDC mark and cam slots are right (the slots just plain straight up!)
    In G-heads,SLOTS STRAIGHT UP!
    So simple and so many ways to mess up and bend valves..
  7. #5287
    Eltham vic
    thanks for that guys
  8. #5288
    Top End
    anyone know the name or brand of these extractors ive seen them on a few RGs
  9. #5289
    That is a Toysport Header.
    The TRD header is about the same.
    (\__/)
    (")_(")
  10. #5290
    Junior Member Backyard Mechanic egamirrorim's Avatar
    Zammo, do you have any other pics of those extractors, from side on? They look to be 4 - 1?!
    I've looked on the Toysport website but there doesn't seem to be any way of contacting the site owner.
  11. #5291
    Aug 2009
    Rgds, Willofan
  12. #5292
    those headers look more like a 4-2-1 type, with separated primaries and secondaries.
    You can see there is part of the flange visible between no.3 and no.4 runners, which suggests that it is a larger flange to accommodate two runners (not just one). You can also see that no.2 and no.3 merge to the one collector towards the front end of the engine, and no.1 and no.4 merge further away - suggesting these do not merge to the single collector.
    I'd suggest there are some 2-1 secondaries that match the pic above, which you are not seeing.
    ...... butt scratcher?!
  13. #5293
    I think witzl is right. I've seen similar extractors and they come in 2 peices. Defiantly a duel flange in the pic.
  14. #5294
    Top End
    well they look like a bolt on replacement for the factory cast headers
  15. #5295
    Thanks, Witzl. I didn't take that close a look!
    Zammo, if you're chasing a replacement for the factory exhaust manifold you can get new 18RG extractors through hurricane headers. You'll need to find a local distributor for their products as they did not deal direct to the public when I bought mine, but they should be able to help you with finding the right exhaust shop to supply the part.
