Cheers timbo ill round up all my shit and chuck up a thread
Going price for a running rg is 1000 bucks... Sell the efi seperately for a few hundred.
Ok people. After a long fight with my car before I realsied I didn't hook up the neutral switch and then my fuel pump not sucking fuel. I finally have cranking and fuel. But now I have no spark coming from my coil. Can someone quickly verify what wires I need hooked to the coil/election ignition setup please.
I know that this is pointless & gonna shit ya, so sorry, but anyhoo; I recently bought 2 18RG's for 400 bucks. #1 is complete & a runner with 40 mm Dellorto carbs & Pacemaker extractors, new clutch & Celica 5 speed box. #2 is in a thousand pieces, but all there with 9.7 pistons standard exhaust manifold & 40 mm Mikuni solex carbs + air box & another 5 speed celica gear box.
O.
Depends on what kind of elec ign you're running.
A normal early toyota jobbie (so, RA60 21R, RN85 22R-C, 18RGEU) only needs:
-Power under run/crank (on/start)
-Ground - the body of the igniter needs to be grounded (no wire)
-Inductive sensor signal - from the distributor
That's all it needs to fire IIRC
It has all that. The igniter is putting the power out for my fuel pump, maybe my coil is shagged.
My igniter has an output from the coil in the wiring loom.
ok i obviously fail at 18rg, there is no signal when i hook a test light to the coil and crank it.
ok i have on my coil, 2 wires from the igniter, a wire from the loom on the car hooked to the coil, a wire to my thermo relay. and that is all. my igniter has 3 wires hooked up and 1 not. 2 to the dizzy, 1 to my fuel pump relay.
changed the coil and changed the igniter, and fitted a new cap and rotor. still nothing
Can you put up some pics and/or a wiring diagram of how your car is currently wired?
I'm not sure how but I'm pretty sure I've hooked the coil up wrong I just read the wiring diagram again and swapped the wires over. Just waiting for my battery to charge again.
Ok, me again...
I'm learning all this as I go, and I didn't realise I had a misfire at idle until a few people pointed it out.
When I pull the lead off Cyl #1 and Cyl #4, it makes no difference to my idle speed
I replaced my distributor cap, rotor, leads, and plugs. I swapped leads and plugs around to double check. The problem stays with Cyl #1 and #4.
I double checked the electronic ignition was in phase by cutting a hole in an old cap (as per the XR700 instructions) then shining a timing light in there. All good.
Cam timing is set with the crank at top-dead center and the lobes on Cyl #1 facing outwards ( <o o> ) making sure the camshaft slit is facing straight up.
Playing with the mixture settings on Cyl #4 makes a difference to idle speed, but Cyl #1 makes no difference.
I'm yet to swap the carbs between Cylinders to see if the problem goes to Cyl #2 and #3. I'll try that and report back tomorrow.
Does anyone have any other ideas why I have a misfire?
