Page 343 of 392 FirstFirst ... 243293333341342343344345353 ... LastLast
Results 5,131 to 5,145 of 5875
  1. #5131
    I figure it's about time I put a picture up of mine.
    Soooooo close to being dropped in.
  2. #5132
    looking good man!
  3. #5133
    Sydney N.S.W
    Quote Originally Posted by lilcrash View Post
    I've seen a few people hook up a fpr wrong, just check that its right. I hooked mine backwards one day. Car wasn't happy.
    i'll have another look at the setup for the fpr, also double check the vacuum hose connection that feeds off it.
  4. #5134
    Sydney N.S.W
    Uploaded with ImageShack.us
    Well, I've decided back to basics. going for new pins and proper soldering.
    if this doesn't work, i'm gonna put in an 18RC carby.
    Tried wiring the pumps direct, avoiding AFM, it ran but rough.
    So, back to the drawing board.
  5. #5135
    Are you saying it stayed running with the fuel pumps hard wired?
    Man, if you get really stuck, you can send the loom to me to look over/fix man.
  6. #5136
    Sydney N.S.W
    it ran for a short period, then died. As I said it ran rough, so don't know what to make of it.
    I want to put new pins on the plugs or locate new plug altogether, as I can't get the pins out.
    the original wiring on the plugs is pretty shit.
    Also extend the length of harness, to relocate the ECU.
    RA35GT, again thanks for the offer, I might take you up on it. I'll let you know.
    Anyone have any idea where to locate new ECU plugs?
  7. #5137
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    Does it continue to pump fuel after initial start up I've had an experience recently where the comp cut off fuel delivery after about 10 seconds
  8. #5138
    Sydney N.S.W
    It ran for longer than 10 sec. I needed to pump it a few times to keep it running as it ran rough .
    I finally figured out how to remove the pins, tomorrow I will re-solder all the wires and extend the harness.
    Looking at the harness, I have a suspect ignition wire connection. This was deep behind the dash and I think I missed it.
    I'm thinking this would give me the cutting off of the engine. Where as if it was fuel, a run on effect would be evident I would think.
    does that sound like it could be he culprit?
    I will know when I re connect everything.
  9. #5139
    Feb 2012
    Sa
    Does anyone kno off hand the flow rate an pressure of a stock eu need a fuel pump for my efi conv
  10. #5140
    40psi not sure of flow rate. Most people just use a vl fuel pump, the pressure reg will keep it happy so doesn't matter if the flow is too high.
  11. #5141
    Feb 2012
    Sa
    Cheers ill grab one
  12. #5142
    Sydney N.S.W
    I've checked the rfpr. It replaced the original one and placed it in the same place at the end of the fuel rail with return back to the surge tank - then main tank.
    vacuum is taken from the intake, but is tee'd off with the dizzy vacuum advance. Any problem forseen with that connection?
    I've read some people put the FPR before the fuel rail input, not sure if thats right.
    I ran the FPR at 38psi up to 45 and had no problem. till now..lol
    With a Rising FPR on an 18rgeu, would multi hole injectors be better off for atomising, than std single pintle?
    Its been covered before, regarding the single over multi, but not with the added Rising fpr.....
  13. #5143
    Putting it before the fuel rail would just pressurize your fuel lines not the injectors so afaik would be pointless.
    As for your rising rate fpr, it wouldn't add fuel on an na motor as it uses boost pressure to add fuel.
  14. #5144
    Anyone want to swap their stock exhaust manifold for my extractors?
  15. #5145
    hey folks,
    was wondering if anyone had a selector fork for 1st/2nd from a w50 (least I think its a w50, 5 speed on an 18rg)
    I have one that is in 2 pieces
    Are these stocked anywhere?
    Dave
