Page 364 of 392 FirstFirst ... 264314354362363364365366374 ... LastLast
Results 5,446 to 5,460 of 5875
  1. #5446
    Pffft, I used to rev mine to 8000 rpm on a daily basis, both the n/a screamer and the turbo.....both had fair sized cams though, light flywheels, one with stock pistons and the turbo with forgies. Rods and crank are virtually unbreakable....as an oversqaure engine these things do actually like to rev
    Cool, good to know it's not going to be putting valves into pistons so easily. I honestly just had know idea how high i should be taking it. It should pick up a bit once I bin the 88270 cams for some 88210's, but I think some aftermarket ones would be helping you get all the way up to 8k
    Quote Originally Posted by 73GTV View Post
    Sounds like a really good tuneup is in your future. Compression test of the engine and a good read of the Repair manual to see if your engine is within the limits. Is this a recent rebuild and if so have you given it time and enough use for the rings to seat? Which carbs do you have and what do you know about jet sizing for your application.
    Performance requires being very stubborn and reach for perfection, and to never settle for almost right. Good Luck with this, because I know you will get it right.
    aka: Solex carbs have a metering block at the bottom of the carburetor that will fill with crud. This will restrict you fuel flow and rob your performance.. Just a thought...
    18RGEU's the EFI variant matey. I'm not a carburettors kinda guy. Keep in mind the 88270's have the lowest compression and most tame cam profiles of all the 18R-G variants, so this might just be what the performance is like. It's mega torquey though. It kinda drives like a 22RE that actually wants to rev past 4k rpm.
    I bought the engine as a 'recent rebuild', ~4,000km on the clock. I pulled it down and it has definitely been rebuilt. It doesn't feel like there's a mechanical problem, it's just more tame than most 18RG variants.
  2. #5447
    I take my 18RGEU (Stock as a rock) to 7k all the time. It loves it!
    Doesn't make much power up there, but it sounds cool LOL
  3. #5448
    Quote Originally Posted by RA35GT View Post
    Hur hur, this is kind of what I was hoping to hear as my 18RGEU is totally stock except for a unfilter, extractors / 2" stainless exhaust and a light flywheel. Cam time!
  4. #5449
    Also, with your slipping belt problem.
    Make sure you're using the right width belt.
    The later ones used a 13A belt rather than the 11A! (Yes, I went through a few 11A belts before realising lol)
  5. #5450
    Yeah i've definitely got a 13A on there but after getting the swingarm powdercoated the alternator doesn't slide so well, so i've just got to take the swingarm off and sand it a little so it doesn't create massive resistance when attempting to tension the belt.
  6. #5451
    Ahhh.
    I use a small length of broomstick to help tension the alt. (obviously don't go overboard with it)
  7. #5452
    Jan 2007
    queensland
    Hi Guys,
    18RGEU running 195500-0285 Blue top injectors... they look to be quite rough, and one of the clips is cracked/broken.. so i am trying to find a set of new replacements rather than have the old ones reco'd and superglue the plastic bakc together *sigh*..
    i can buy brand new 22RE ones - 23250-45011, many suppliers in the USA and China etc etc..
    i am having trouble however finding info on size and impedance, the old style denso plug is the same, and install o-rings etc is fine.
    they would be slightly bigger? it's running a very old Haltech so it can be tuned regardless if they are drastically bigger, but i was hoping to be able to drive the thing for a bit first, so i'm hoping they are of similar size, and the same impedance.
  8. #5453
    Sydney N.S.W
    I know the std injectors are the 210 cc's, you can go for the 4agez type which will suit.
    i have a set of 240cc that suit 18rgeu's and 360cc, i can get the denso number for you.
    otherwise try finding the early RX7 injectoers, their 460 cc brown top feed, low imp, i have a set also that i can get the numbers for you. these are quiet easy to find.
    i think from memory in the USA they have mitsubishi eclipes injectors which come up often on ebay.
    this i think is one of the better injector info sight i've seen.
    http://injector-rehab.com/shop/
    go to top right click Knowledge base.
    click onto injector pic & flow rates, scroll down to nippon.....top feed.
    then see the nippon numbers and flow rates, u can click on these and see an actual pic.
    not to mention the rest of the sights info on duty cycles and more.
    btw its for all injectors
    hope that helps.
  9. #5454
    Quote Originally Posted by mattysshop View Post
    22R-E ones SHOULD be low impedance as they run a resistor block for the injectors, which has the same resistance as a 18RGEU injector resistor block. In fact I am using one on my 18RGEU setup.
    I know this is true for 22RE RT142 Corona.
  10. #5455
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    Quote Originally Posted by Blinga_22rte View Post
    So I got a tractor for the Stout. You guys twisted my arm. Haha
    88253 Head with standard cam
    Came with Dellorto DHLA 40's and manifold
    Spare webber 45mm ported manifold.
    Pace maker extractors
    There will be a few things I need to get for it.
    Throw out lever, slave cylinder and shifter for the box.
    Has a Falcon alternator, is there a bracket assembly for that I do I need to fabricate one?
    Also a kit to convert the points distributor to electric. I'm lead to believe the instructions are on here somewhere?
    I've been looking at camtech site for a re-grind, I'm after a profile that would suit it, since the Stout is a truck, it will have to behave like one. (Torque Low/Mid range power). Any suggested cam profiles?
    I don't want to loose that Lumpy idle!
    http://www.camtechcams.com.au/toy_4cyl_2tg3tg18rg.html
    http://www.toymods.org.au/forums/tec...izzys-how.html
    instructions are here
  11. #5456
    sus-023 Backyard Mechanic Slidin23's Avatar
    Apr 2007
    123 fake street s.a.
    anyone had experiance with over reving these engines?
    i took my ra23 celica to drift prac last night and was giving it shit the whole night. dont have a working tach but i was 8000 plus in second gear in the s's
    its a rebuild blanaced motor with 22r pistons and a ported and flowed head done 5000km since rebuild if that.
    last session i noticed it had a drop in power so i backed off. heard a big end knock. came in and noticed the oil was slightly below full. had it fillled to over full before
    ad now i noticed an oil leak to... :/
    gonna pull the motor apart in the next few weeks when i have time..
  12. #5457
    They loose oil pressure in corners due to oil sloshing away from the pump. Be very careful.
  13. #5458
    Sep 2007
    Georgia
    Build yourself a better oil pan with internal baffles. Additional capacity will help. Good Luck
  14. #5459
    Apr 2007
    i have a front sumped motor as i have rack and pinion..
    the motor sounds a lil rattlly at around 3000. do you think i could just clean up the crank and wack a set of bearings back in it and itll be fine? or do these cranks crack and mark easy... ??
    also anyone got and pics of their baffled sumps? and what would be considered over reving for these motors?? it seamed to love to rev the whole night! i have double valve springs and didnt hit valve float once! was really impressed
  15. #5460
    Eltham vic
    another alternative is use an accusump its a cylinder that contains pressurised oil and when there is a drop in oil pressure it forces oil through the system
    i bought one on ebay last year for under $100 from the states i will post up a piccy tomorrow
    or try this link
    http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40
