Page 264 of 392 FirstFirst ... 164214254262263264265266274314364 ... LastLast
Results 3,946 to 3,960 of 5875
  1. #3946
    Rens, What carby manifold do you have?
    I'm still looking for a manifold with 88211 casting number on it.
    It's one of the long manifolds.
    If you've got one, I'd be happy to swap for one of my short manifolds and cash.
    (\__/)
    (")_(")
  2. #3947
    Junior Member Grease Monkey Rens's Avatar
    Nov 2010
    i just had a look, it's got 17111- 88211 cast into the runners closest to the distributor. How much difference is there between this manifold and the regular one?
    My engine's in a RA40 and is a little tight near the brake master.
    i'll measure it and give you an overall dimension of my manifold
    Edit: 90mm overall length
  3. #3948
    Here's a pic of the manifolds.
    I'm after the one on the left, the long one.
    There were two different long manifolds and a few short ones (about 3 from memory) used on the RG motors.
    (\__/)
    (")_(")
  4. #3949
    nice datsun Backyard Mechanic TRD184's Avatar
    Jan 2009
    New South Wales
    Hi all, back yet again for more info, i know its come up before but im looking for a set of high compression pistons for the 18R-G, is there any other options aside from Arias, Toyheadauto, or companies that use arias, like paradise racing? i want ot stay with a 2L and toyheadauto dont appear to have them. Toysport wont get back to me either. cheers
    my RA23 http://www.toymods.org.au/forums/showthread.php?t=57060&page=2"]
    It's 106 miles to Chicago, we got a full tanks of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
    - Hit it.
  5. #3950
    Quote Originally Posted by TRD184 View Post
    Hi
    Shame you don't want to go 2.2,L I'm about to sell off a set of 92mm HKS pistons also going to sell some 302 and 288 cams plus a set of 45mm ITB with 550cc injectors
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  6. #3951
    Go to arias/atomic pistons direct, no middle man.
    I found them helpful and mostly pretty good on the time scale, and can do what ever size you want.
    Unless you have an issue with the pistons themselves?
    Now - RA23-WRX
  7. #3952
    Jan 2009
    New South Wales
    no its more the order form they ask me to fill out, its ridiculously in depth, alot of the things i cant answer, and i dont have a sample piston to give them, so i was hoping for an "off the shelf" alternative.
    http://www.ariaspistons.com/products/orderform.pdf
    - Hit it.
  8. #3953
    Dont worry about the form, they know the 18RG form well and will take you through it, and will already know the information that you are not sure about.
    Just email them telling them what bore size you want and tell them you want to up the compression, and I reckon they will do the rest for you.
    Now - RA23-WRX
  9. #3954
    Jan 2009
    New South Wales
    aaah swell, ill email them and see if they can do that for me! would save me a great deal of hassle. thanks!
    - Hit it.
  10. #3955
    Sydney N.S.W
    Quote Originally Posted by ra_28 View Post
    Hi
    Alex
    ra_28, can you tell me more about the cams u have on offer shortly...interested..
  11. #3956
    Junior Member Backyard Mechanic egamirrorim's Avatar
    OK, so I'm trying to connect up this fuel pump but the green bible is not very helpful! In the fuel system chapter there are 17 pages for the carbs but only 2 for the pump and it doesnt give you the most important info!
    Can somone fill in the blanks for me please?
  12. #3957
    Jan 2009
    New South Wales
    what do you want to know? where those fittings go?
    5:goes to the carbs.
    6:is the return
    7:is the supply line
    when i brought a new fuel pump i had to change #5 to a barb fitting like the others, for some reason it came with a threaded fitting, i assumed it was for an 18R
    - Hit it.
  13. #3958
    Jan 2009
    New South Wales
    hey all, ive ocntacted arias regarding pistons, and they were more then helpful (thanks silverRA23 )
    since im here, i figured i may aswell make it a 2.2L, but ive got a set of 40mm dellortos i was plannning to use, is it worth going 2.2L if im going to be using 40mm sidedraughts? (wont cost me any extra to do so) or will the 40's be inadequete and i should stick with 2L? dont really want to have to by 45 webers or something if i dont have to. (unless someones got a cheap set? lol )
    edit: been doing some reading (18rgte reference thread, this thread http://www.toymods.org.au/forums/tec...rg-2-2l-4.html etc, on 2.2L, and theres people discussing using different cranks to achieve 2.2Ls, i was under the impression that i could bore it out to 92mm, using custom 18rg pistons from arias, and that was all it took,which, looking at the engine, makes sense, but i want to clarify before i order a set of pistons i cant use)
    - Hit it.
  14. #3959
    My solexes are 40's and they are more than happy with the extra capacity i gained going to 92mm pistons from arias, so I would say go for it.
    When you do put that order in, also make sure you order a 92mm head gasket from cometic as the stock one won't deal with pistons that big
    Now - RA23-WRX
  15. #3960
    Jan 2009
    New South Wales
    aahk brilliant what compression ratio are your pistons if you dont mind me asking.
    will definitely do so
    - Hit it.
