Heavy handed tightening apparently. Must have been a serious breaker bar or something I would have thought to make it break!
18R-Cs don't have those gears.
The 18R-G shaft is longer so that it can be put on.
Just out of interest, how did he break the gear?
(\__/)
(")_(")
Had a mate that had the gear on the front of that shaft in an 18rc just randomly snap off and go through the timing cover plate :-o
Just happens i guess.
bEn
FJ40 landcruiser
HJ47 landcruiser
FJ55 Landcruiser
MS65 Crown
The gears which are driven by/drive the chains are the same between the 18R-C and 18R-G. On the R-C, the dizzy drive gear is at the back of the shaft, and the dizzy drives the oil pump. On the R-G that same gear is used to drive an idler shaft which drives the oil pump, and there is a different gear in front of the chain cogs which drives the dizzy and not the oil pump.
The first post somewhat confuses me on this, though I am assuming that it is the gear that drives the dizzy which has broken. In which case these are 18R-G specific, and I am yet to find one new. Don't think I have a spare one anywhere either at the moment.
The first post was probably confused as I was relaying what he mentioned.. having never pulled one apart I took his word for it.
Thanks for clearing it up. Yes it is the dissy one he broke.
*subscribed*
just joined the 18R-G club
does any company still produce a decent cam for the 18R-G?? i cant find any using google
my RA23 http://www.toymods.org.au/forums/showthread.php?t=57060&page=2"]
It's 106 miles to Chicago, we got a full tanks of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
- Hit it.
Regrinds are probably the way to go. Gives you much more flexibility, instead of having to go with whatever you can find for sale.
Norbie!
www.norbie.net
When looking at regrinds, there are 2 options. First is a standard regrind, which will require much thicker valve shims, and will limit the amount of duration available. The other is a hard face regrind, where they weld new metal onto the existing lobe, then grind that down. This can allow you to run shims in the same thickness range as existing, and you can get pretty much any lift and duration specs you want. You can also drastically vary the open and close rates. There is a mob in Brisbane called Tighe cams (google them) who from memory have a range of profiles to re-grind on file.
^ thanksphonecalls will be made
- Hit it.
Cat cams in Europe sells them as does Kameari both are pricey in my opinion but they are out there. Be safe
Greg
There is another mob in NZ said to be good. Can't remember their name off the top of my head.
http://www.camtechcams.com.au/toy_4cyl_2tg3tg18rg.html
Never used them, but came across them a while ago.
^^ just checked them out, cant find an "off-the-shelf" for the 18RG, BUT, they have distributors in Aus so il give em a ring. thanks![]()
- Hit it.
hey guys, need some help.
The missus has an 18RG in her little 23..... came with the optioned up BHG.. wasnt to impressed. but alas, we move forward to the fix. Head off and back from being smooooothed. Need to bolt it back on. I noticed that some of the head bolts were looking a little rusty and one almost looks swollen so me thinks its had the BHG for a little while. as the prev owner mentioned something about it sitting around in his shed for a few years.. So....
1, Where can I buy new head studs?
2. does any other bolts cross over? 18rc?
Cheers for the help
J
SprinterBoyAus on YouTube
SprinterBoyAus on Facebook
