Results 16 to 30 of 52
Thread: 1G-GTE Head Comparrison
    Default Re: 1G-GTE Head Comparrison
    Josh,
    All three heads deffinatly seem to be based on the same casting so the next step is to check cam part numbers, measure valve sizes and cc the combustion chambers.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Josh,
    Cam numbers should be the same as the head number with a leading 1- for Inlet Cam and a leading 2- for Exhaust Cam...
    So for a 11111-88340 Head an Inlet Cam would be either 1-11111-88340 or 1-88340 (I can't remember which )
    ([][][]II--LT--II[][][])
    I got an open head in the shed (gen2) ill get the verniers out tonight
    KE38 - 2TG
    MS65 - 1UZ
    and ive got two dead gen3s rod so let me know specifically what ya want.
    Black Betty >HERE!<
    (\__/)
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Hay rod should get mos to see if the 1g in his car has a similar number on it
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    You just LOOOOOOOOOVE my cam sticks, dun ya. ;-)
    Facebook | LinkedIn
    FYI 1GGE cams have slightly more lift than GTE cams. Different duration also.
    Simon
    Beige.... The new Black!!!
    Simon,
    Got any specs for reference ?
    7.3mm lift for the GTE and 7.5mm lift for the GE (from memory) I'll check the emails i got regarding this info.
    Simon
    Quote Originally Posted by SIKTOY
    Being an F series head I very much doubt it
    If in doubt power out
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    I had some nice pics of my cleaned ported etd gen 3 1G head.... and I lost them all gutted.
    might have been of interest!!
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    Will give the 1g-gze head part number and cams number tomorrow.
    Facebook | LinkedIn
    Quote Originally Posted by stradlater
    its tomorrow
    its tomorrow
    Give us time to go from Melb to Shepparton and back and take the damn thing apart...
    Quote Originally Posted by twentyEight
    god damn these mexicans needing more time
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 12:36 PM
  2. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 08:29 PM
  3. 3s-GE Head gasket
    By SilverSt162 in forum Tech and Conversions
    Last Post: 03-08-2006, 09:44 PM
  4. Matching your head to your o-ringed block.
    Last Post: 09-05-2006, 03:14 PM
