doesnt make sense as the Gen3s were the latest 1G and theyve all had 88340 so far.![]()
gen 1 soarer up to 88/01 mark11 and chaser /cresta/ supra up to 88/08 all take 88340 head from 88/08 all take 88341 but early pnc s/s to 88341 which means you can use the late head in place off the early with a few extra parts as per the toyota list in japan
Black Betty >HERE!<
(\__/)
my dead 1g...88340 also, .....
i also have NA cams to go in the new mtr...with the cam gears,
blake
Well, after taking apart the GZE today, there is no number on the head at all!![]()
Also, the cams were numbered "No 1" and "No 2" instead of the GTE cams which were 1-88340 and 2-88340...
Very unexpected...
Yup.... And further unexpectedness showed that the bottom end of a 1g-gte and a 1g-gze were exactly the same??!?!
Did you pull the pistons out I think they have different comp ratioOriginally Posted by stradlater
reputation is nothing knowledge is everything
RA23 1GGTE 12.3@110mph
1980 RA40 now getting a 1G with new picsLOOK
Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
Sorry, I forgot to mention that bit.
The pistons are different, more dish, so lower comp. I'll get a thread and the pics up later
The 1G-GZE rod is supposed to be shorter than the 1G-GTE Rod ?
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
No, rods same length. If you are referring to the fact I've posted you can stroke the engine by offset grinding it with a GZE rod, you have to machine 1mm of the top of the piston. I have also posted that this is fine, they have like 5-6mm of ring land, and it affects the compression bugger all, like .2 of a point.
For anyone trying to build an engine, every single head, from every single series, are all the same port and chamber castings. There are monor differences elsewhere, like the ZE heads don't have oil feeds for turbo's, and in the centre valley where the plugs go, NA heads have 6 welsh plugs not 3, but they are all the same from a power production point, just use what you have, or whats the cleanest.
6BOOST
Just to clarify Kyles point as I interperet it. For anyone not familiar with offset grinding of cranks. The Crank bigend location is ground offset making it smaller. The GZE rods (At least some of them if not all) have a 2mm smaller bigend bearing making them pefect for the smaller bigend once the crank is ground.The rods are not 2mm shorter !
Kyle, Feel free to correct me if I misunderstood.
I'm pretty sure you are correct, but not in the case of the GZE we pulled apart on Sat...Originally Posted by TheToyman75
Further clarification. The big end is 2mm smaller than the late 1G Bigend (Gen 3 for example)Originally Posted by twentyEight
Ie all 3 engines you have stripped would appear to be the early series bottom ends
What you need now is a Gen 3 crank, not more early series Rods. The question is tho... What are the main bearing sizes ?? Do you need to use a Late 1G Block, to use a Late 1G crank ??? I am exppecting the answer to be yes but have no idea. Or does something else conflict ?
mains are the same as far as im aware
have dead gen3's for the cause here. Instruct me ol wise ones.
Black Betty >HERE!<
(\__/)
