Results 1 to 15 of 28
Thread: 2tgue & 3tgtue info
    Tasmania
    Default 2tgue & 3tgtue info
    I have a 2tgue well i know the head is but am unsure about block. How can i be sure if i have an original 2tgue block. Various numbers on the block?
    Secondly if i was to convert to a 3tgtue do they bolt straight in like the 2gtue. Could the original diff and brakes be strong enough to handle 3tgtue. If not what sort of replacment parts would you recommend.
    Junior Member Domestic Engineer Hurricane's Avatar
    Default Re: 2tgue & 3tgtue info
    what car have you got? and are you taking aaaabout makin a 2tg/3t or a straight 3tgtue swap?
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Tasmania
    have a ta22. Thinking about a 3tgtue swap
    Why?
    If you gonna do a engine swap y not go a 4AGE (GZE if you want FI)
    the T series are getting old and parts are getting harder to find
    Quote Originally Posted by merc-blue
    Why?
    The "t" series engines have a distinctive sound, maybe he wants to keep that. And then there's that whole old school charm they have...
    Yes,
    But marcus. over boost = broken T series parts which i could have used,
    Nah seriously now,
    If you want forced induction your chassing HP a old 3TGTE dont make great power for a turboed engine when a midly worked 4A can and will do it more reliably and also if it does fail parts can be had quickly and easily.
    Chippa whats your reasoning for going to a 3TGTE?
    Yes,
    Nah seriously now,
    Dude did you bump your head or get a labotomy over Xmas ?? I am at work now but will check this thread tonight.
    The 3TGTE will "almost" bolt in. Turbo oil drain requires attention (See Jason - aka YelloRolla) The 3TGTE is a lack luster performer in stock trim but with the $$$ you would spend build a 4AGTE you can build a very sweet 3TGTE.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Both!
    yes the 3TGTE will slot in but for the cost of parts and such i recon its worth it.
    i mean it cost over 500 dollars to get new chain sliders and chains
    Id have to agree mate,if it wasnt for originally buying my car with a 3tgte already in it I would definately go 4AGZ/TE. Parts and cheap upgrades etc are easliy had.But I really dont rate the NA version,they sound fast and a quite rev happy but there is about asmuch torque in them as Mr Burns hand when trying to crush a paper cup
    If you have the coin go 3sgte.
    -Just Alloy Radiators-
    www.alloyradiators.com.au
    you dont rate the 2tg??!!!!!
    HEATHEN!!! BURN HIM BURN HIM
    I think he ment the 4AGE...
    Quote Originally Posted by Turdinator
    Yep sure did,If i was going to have a na 1600 in my Celica I would prefer the 2TG for the old skool charm,as both make fuck all power in my opinion so why not just keep it more true to its era,but meh I dont and in actual fact would prefer a 3SGTE over all engines when it comes to my Celica.
    Nath
    Junior Member 1st year Apprentice WeekendWarrior's Avatar
    new south wales
    mate the 2tg is an excellent motor for n/a setups but for blown application they are just no good. my mates got gemini with the 3tgteu and hes got a hi flow turbo and an aftermarket computer etc etc and that thing he just cant get to run good hp. 2tg perfect for webbers or any other high revving setup but they arnt really the best for turbs. i personally was going to go a turboed 4agze setup but ive stuck with the 2tg coz they bolt straight in and they look good in the engine bay with some webers. but as far as parts go the only place i can go to find forged pistons for the 2tg is in the states and i was looking at about 1400 dollars all up.
    - Project "BILLYGOAT" the ta22 found on the edge of a hill
    BEARCON All your construction needs 67 624580
    THE CELICA SHOP COMING SOON
    Tasmania
    thanks guys
    reason for the thought about a 3tgteu is that i had a suspicion they bolted straight in. The cost and rearness of parts is an issue also. What about brakes would the standard ta22 brakes be able to with stand the 3tgtue. I have a 2tgue at the moment. Only problem is im not sure if the bottom end is the proper block or some cheap shit block. How can i tell and what do the 2tgue go like.
    cheers fellas
    Junior Member Backyard Mechanic rob1's Avatar
    Tas
    Quote Originally Posted by WeekendWarrior
    you're not looking hard enough then. as for the statement that they are no good for blown application, well, it takes more than an aftermarket ecu to get good hp. i suppose it depends on how much hp you want. remember the t series engine is pretty old, and it's only 8 valve. you can't just bolt a turbo onto a 2tg, dump some forgies in it and think you are going to get 300hp. it all comes down to how smart you build the engine, and how much you want to spend.
  1. 3TGTE basic info needed.
    By Stephen1974TA22 in forum Tech and Conversions
    Last Post: 16-11-2007, 07:30 PM
  2. CT34R Le-Mans spec Turbo .... info needed
    By cptsideways in forum Tech and Conversions
    Last Post: 23-09-2006, 05:46 AM
  3. 2JZ-gte - interference details and random vvti info
    By Draven in forum Tech and Conversions
    Last Post: 18-06-2006, 07:06 PM
