Your idea of de-torquing and replacing one by one does sound good. The one concern i have is the tool you will be using to put the studs in place (im assuming by stud you mean stud, a shaft which is threaded on both ends... and then have a nut on top). Will this tool be able to put the studs in properly with the head on, as most stud sockets ive seen are pretty deep, and need to be so such that the thread is not torn. If you mean expensive aftermarket bolt when you say stud, then I would say that you shouldnt have a problem with this procedure, as head gaskets, copper or not, are best left undisturbed. One thing i strongly suggest is to drain your coolant to below head level before you begin, as you dont want coolant seeping into unwanted places, and possibly putting contaminants in your head gasket seal. Ill bet 1 rep point that you can do it if you mean expensive bolt when you say stud, and no bet if otherwise![]()
I think there will be enough thread to get two nuts tightened together at the top of the thread to give me something for normal socket to bit on to and thread the stud into the block. I'll take your 2:1 though and yeah, the engine will be dry.
