Results 46 to 60 of 75
Thread: 1UZ aftermarket ECU option??
  1. #46
    Default Re: 1UZ aftermarket ECU option??
    There's tons of ECU's that will run the 1uz well, ask your tuner what they prefer to use. Motec, Haltech, Vipec, Link, Adaptronic etc
  2. #47
    Adaptronic, especially if you're going to be playing with it yourself...Also it's 1.5k cheaper than autronic!
    -RM
  3. #48
    Forum Member Backyard Mechanic
    Jan 2011
    unfortunalty I know in life you get what you pay for
    and I promiced myself not to cheap out on this build
    that's not saying go for the most expncive parts out there but if there know to work well then that's the road I'll take
    as I want this car to be reliable more so than powerfull I still want the best from both worlds
    mx83 cressy 1uz r154
    8.5 inch quarter master twin plate now installed
    ba/ r33 brake upgrade, bc coilovers, ttt rca now in bits,rays gram lights 17 +22,trd 2 way
    Link g4+ Xtreme ECU e85 custom extractors and zorst
  4. #49
    Junior Member Grease Monkey Jasper's Avatar
    In terms of reliability, it it probably worth noting that the Autronic doesn't have knock control, unless you fork out extra for an additional module. This module has been 'coming soon' for the last 6 years or so... I ended up using the analog output from a Link Knock Block.
    I have heard rumors that they have finally been released, but stopped playing around with this type of thing so I didn't look into it.
    I believe some of the other alternatives listed above come with knock control as standard.
  5. #50
    Quote Originally Posted by cuttz View Post
    Then it has to be a Vipec V88 at around $2.5k.
    One of the best ECU's around at the moment.
  6. #51
    Jan 2011
    ^^^^ does it have knock control?
    Also able to run seprate coils
    I'm dumb founded that the autronic doesn't have knock control
    does it have a hand controler that shows the knock level like the power fc
  7. #52
    Vipec V88 has two built-in knock amplifiers and does closed loop knock control, also closed loop boost control etc etc which all work well. They're especially good on engines with reluctor triggers and support the non vvti and vvti 1UZ's natively. They have 8 ignition and 8 injector drives, so you dont have to run batched injection or waste spark.
    I've been running a v88 in a couple of my cars since Sept 2008. Had it in my daily-driver forester GT to start with on a built EJ257 etc etc, then took the V88 from the forester and put it in my MX83 when I did the vvti 2J swap.
    Just had a look at the map from the V88 prior to it's removal from my forester, it had run the engine for 32041 minutes and done 2400 starts without a hitch That car's now running on a Vipec V44 "Plug-in" ECU.
  8. #53
    Jan 2011
    cool as
    with the 8 ignition drive does that mean they can drive separate coils with out any other hardware
    ill get into contact with my tuner (dom from protek) and see if he has the stuff to tune these badboys
  9. #54
    Jan 2011
    ive done some searching and have now contacted jpc
    they tuned my mates turbo 355 vn and there the sole dealer of the Vipec V88 so ill wait to hear back from them seen as they have vast knowledge on this ecu
  10. #55
    If you have coils with built in ignitors (vvti 1uz, LS1 etc) then the ECU can drive them directly. I'd expect something like the haltech platinum sport 2000 or Adaptronic E1280S would perform the same as a V88, I do prefer the vipec tuning and logging interface over the others.
  11. #56
    Jan 2011
    well thats good info ive got thus far and exatly why i posted in the first place
    so ls1 coils will work fine?
  12. #57
    They're hard to beat bang for buck, just a bit bulky
  13. #58
    Jan 2011
    cause they also use a lead off them as well yeah
  14. #59
    Jan 2011
    hell yeah thats a start just found me some coils to do the job thanks for that info mate
  15. #60
    Jan 2011
    I'm also looking at buying a q45 throttle body to mate with my m112
    I should have no problems running a q45 on a 1uz with an aftermarket ecu right
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 08:10 AM
  2. Blocking ABV with aftermarket ecu
    Last Post: 17-01-2007, 01:09 PM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 07:31 AM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 11:17 AM
