Results 61 to 75 of 75
Thread: 1UZ aftermarket ECU option??
  1. #61
    Default Re: 1UZ aftermarket ECU option??
    FWIW - I run the LS1 Coils, 1uz, Haltech Sprint 500 (less than $1k), 7m-gte injectors, 1uz auto and GT4094 with 10psi boost at the moment.
    I'm a big thumbs up for the Haltechs.
    Facebook | LinkedIn
  2. #62
    Quote Originally Posted by cuttz View Post
    I'm also looking at buying a q45 throttle body to mate with my m112
    I should have no problems running a q45 on a 1uz with an aftermarket ecu right
    With an Aftermarket ECU the Q45 will be fine provided you run MAP.
    Facebook | LinkedIn
  3. #63
    Forum Member Backyard Mechanic
    Jan 2011
    I would run a map anyways seening as I'm going blown
    Stradlater do the haltechs have knock control ?
    And problems with idle etc
    mx83 cressy 1uz r154
    8.5 inch quarter master twin plate now installed
    ba/ r33 brake upgrade, bc coilovers, ttt rca now in bits,rays gram lights 17 +22,trd 2 way
    Link g4+ Xtreme ECU e85 custom extractors and zorst
  4. #64
    I don't use Knock Control, I don't know whether they do, my assumption is that they do. I have seen the wires for knock sensors on the looms.
    I haven't had any problems with idle, infact I don't even use an idle speed controller for mine and it idles fine. Starts first turn too. TBH It's uncanny how easily the thing runs, I almost think i've done something wrong!
    Facebook | LinkedIn
  5. #65
    Jan 2011
    Cool to know I'll look into it
  6. #66
    Probably don't need to bump the adaptronic more than I have, but it does have closed loop idle control, knock control, ignition, fuelling and boost...
    -RM
  7. #67
    Jan 2011
    How much for the adaptronic
  8. #68
    The model that mullett has (e420c) has been superseded by the e420d, which is 990 + loom. There's a model a little above that, 440 select at 1399, which has a little more inputs and launch control/flex fuel. Then there's the e1280 at 2k. This will allow full sequential operation of the engine along with a whole bunch more extra input/outputs. You used to be able to the e420c's in group buys for less than the retail price.
    Do you plan on logging/displaying/warning function for say, oil pressure, fuel pressure, suspension travel, tire temps, acceleration and brake force sensors? The e1280 and V88 both have a lot of extra analogue inputs that you probably won't use.
    The e420d (or V44, sprint 500) will probably suit your car fine unless you really want seq. injector and ignition operation.
    Like JP said, the tuner's going to prefer the product they're the happiest with. The V88 is a good unit but I'm cheap and wouldn't pay that much for an ECU so I run a megasquirt which does everything I want and more.
    It all depends on what you want out of the ecu and how much you want to pay for it.
  9. #69
    Jan 2011
    well jpc still hasn't got back to me with the pricing for the vipec yet but adam from mms said he can get me a adaptronic on the cheep that will do everything i want it to so see what he comes up with for me
    all i want it to do is have knock control for safety sake
    use map sensors and air temp separate coils etc
    give a good tune and just be able to jump in and thrash it with out any hick ups
    adam recons there a pretty sweet unit for the money and seeing as he uses one on his own 1uz and a few on hear like them shouldn't be to bad at all
  10. #70
    did you phone JPC?
    I'd expect a V88 to be around $2400, V44 around $1700. Both with 2m loom, air temp and coolant sensors. V44 has an onboard map sensor, need an external map sensor with the V88
  11. #71
    Jan 2011
    hey no i sent an email through there website
    very good to know mate
    what are the map ssensors worth?
  12. #72
    you can use any map sensor you want, I'm using a ST215 3sgte sensor on my 2J as it reads to 22psi.
  13. #73
    Jan 2011
    Just had a good read on the Adaptronic website
    it seem the new models have built in map sensor witch is a huge plus for me
    also the other feature are on par with other brands
    they realy are a cool unit
    and for $990 and $1300 for the flagship model can't go wrong
    just hope my tunner has the software to tune it
  14. #74
    the adaptronic tuning software is freely available: Downloads | Adaptronic - Energize Your Engine!
  15. #75
    It's 990 for the base model, 1399 for the next one up and 1990 for the flagship.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 08:10 AM
  2. Blocking ABV with aftermarket ecu
    Last Post: 17-01-2007, 01:09 PM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 07:31 AM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 11:17 AM
