Page 14 of 41 FirstFirst ... 4121314151624 ... LastLast
Results 196 to 210 of 604
Thread: TA22 + rack and pinion
  1. #196
    Default Re: TA22 + rack and pinion
    I know that the ke70 rack is too wide but as there is no rack that is exactly the right measurements I have decided to go with it because I have 3 of them so if I stuff up I can redo it and also if the rack ratio is not enough after shortening it then a quafe quick rack can be shortened to fit the shortened ke70 housing.
    I'd rather modify an existing rack to my requirements than use a rack which is close to the needed measurements.
    Re the ae82 rack I recall that someone here on toymods has previously tried this and concluded that they would not go down this path again for some reason.
  2. #197
    Ed (Shelldrake) and I went and looked at a TA22 GTV (fake, but that's another story) with R&P Steering, and it looked very similar to the KE70 setup that I have in mine, but the dude (tool) didn't know what it was out of...
    Ed took some photos of it also... I'll get him to post them up...
    ([][][]II--LT--II[][][])
  3. #198
  4. #199
    Grease Monkey 1st year Apprentice 4AGTE_TA22's Avatar
    Just a thought i had while reading through this topic is it possible to use a shorter lca and modify the x member to keep the same overall track to accommodate the larger size of the rack eg. ae82 is not that much longer. Not sure if this is an option but just thought id put it out there.
    Dave
  5. #200
    ****** Backyard Mechanic 79GT's Avatar
    i think that will increase bump steer....and i think the ackersomething (ackerman...i think) angle would significantly effect steering....my 2cents worth.
  6. #201
    bump steer will not be affected as long as the tie rods and lca are in proportion. but instead of shortening the rack which is what everyone seemed to be thinking, is it possible to increase the distance between the lca mounts but keep the track the same by decreasing the lengths of the lca and tie rod
  7. #202
    Ackerman angle would only become more acute by shortening the LCAs, which presents nasty issues.
    That one which Shelldrake popped up is most certainly a KE70/AE86 rack.
  8. #203
    Jan 2008
    Canterbury
    Quote Originally Posted by shelldrake
    hey any chance you could take a pic of your setup from the front of the engine bay looking back at the firewall,
  9. #204
    It's not his setup, it's a setup that was on a TA22 GTV (was really an LT) that was for sale on eBay...
  10. #205
    Ok here is what I've do so far on the my steering column
    Drilled out the spot welds and knocked off the ta22 column end and did the same to the ke70 one. I had to cut a bit off the ke70 one as the OD of the ta22 column surround is larger than the ID of the ke70 bit that I knocked off. This was welded together after getting the exact position right. The ke70 lower half of the shaft has a bearing on it which is why you need to fit the ke70 end to the ta22 column surround.
    The actual column is a two piece that comes apart as below
    Ta22 top half of shaft
    Ke70 lower end of shaft
    Fitted together
    the firewall plate will need to be modified to make the hole bigger so the ke70 column surround end will fit through it. This will mean that the nuts that the bolts used to secure the end of the column to this plate will be chopped out. So to get round this bolts will be welded to the plate and nuts used to hold the column end to it rather than the stock ta22 setup which uses bolts into the nuts that are part of the firewall plate.
  11. #206
    Jan 2008
    Canterbury
    Quote Originally Posted by twentyEight
    oh my bad was just interested to see how much of an agle the shaft came out on as my exhuast is on that side and so far ive been having trubble finding space for the exhaust after the turbo .
    cheers for the correction
  12. #207
    so from this we are assuming that you are using the ke70 rack. awesome info mate, have wanted to do this for ages. keep the info coming.
    has anyone actually put a quaife quick rack into a ke70 housing?
  14. #209
    Yeah, i had one in there, and one on the shelf for photos.
    Ask away, but im interstate this weekend and no net.
  15. #210
    Quote Originally Posted by 79GT
    Just remember though that the rack is too wide for the 22 and needs to be shortened to be used so if you do get one dont go thinking it will be perfect.
  1. Can you adjust steering stops with rack & pinion?
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 22-07-2012, 01:30 AM
  2. rack and pinion steering - new pinion? from where?
    Last Post: 20-05-2006, 06:14 PM
