Page 41 of 41 FirstFirst ... 31394041
Results 601 to 604 of 604
Thread: TA22 + rack and pinion
  1. #601
    Aug 2009
    Default Re: TA22 + rack and pinion
    Quote Originally Posted by hsmidy View Post
    Couldn't just swap steering arms side to side and flip to be front facing?
    I thought about swapping the arms. Main problem with that is the lower ball joint and tie rod end taper is upside down. Which is why I suggested custom making steering arms. Also thought of machining tapered bushes and drilling/ reaming original tapers out to straight holes that's when realised it would be just as easy to make new ones.
    Another advantage of front mount rack is reducing steering column/ link angle which seems to be a problem on current conversions.
    Fair comment to raise though.
  2. #602
    Feb 2015
    Quote Originally Posted by ToyTA22 View Post
    I looked at using Mk1 Escort rack since quick racks are readily available from UK. Only problem is they mount front of crossmember hence rotate wrong direction. Unless someone wishes to modify crossmember and sump on front dished engines then make/buy steering arms.
    I forgot to say. Thanks for putting info up.
    could you not buy a LHD rack for an escort and flip it? should but steering connection on correct side and act like a rear steer rack. anything else im not considering?
  3. #603
    Aug 2009
    Quote Originally Posted by AM27 View Post
    That is a high possibility of working. Only thing I can see is it would need to be a Mk2 rack due to metric tapers on tie rod ends, there is though no guarantee the Toyota and Escort tapers are the same but easier to ream to matching taper than making new arms.
    Good call on thinking the idea.
  4. #604
    Feb 2015
    for anyone that is interested i found this while browsing yahoo auctions;
    https://page.auctions.yahoo.co.jp/jp/auction/s525280190
    some guy in japan is making electric power steering kits for first gen celicas, $1500 aud + delivery. user name on yahoo auctions is zeke79bb in case that link dies.
  1. Can you adjust steering stops with rack & pinion?
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 22-07-2012, 01:30 AM
  2. rack and pinion steering - new pinion? from where?
    Last Post: 20-05-2006, 06:14 PM
