Okay more details. Taking an oxy torch to the aluminium housing and whacking it in a vice I managed to get it apart as I suspected could be done.
The tube in its glory
The tube only goes in a certain depth in the aluminium housing as there is a lip to stop it
now the tube end is a bit smaller diameter than the tube.
So now to shorten this housing I wont have to weld it after all. What will have to be done is to chop the required amount off and then recreate the smaller diameter section on the end and the beveled end edge.
Lucky I have access to the lathe at work to do this. Then to fit it back together heat up the aluminium housing and freeze the tube and whack together.
The bottom pinion bearing came out while I was torching the housing and here is the markings on it for reference if you want to replace it.
