Page 10 of 21 FirstFirst ... 8910111220 ... LastLast
Results 136 to 150 of 301
Thread: Standard 1G-GTE Dyno.
  1. #136
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default Re: Standard 1G-GTE Dyno.
    Quote Originally Posted by SIKTOY
    Should be close to what I ran 13.3 street tyres 12.3 slicks mine had the same power as yours
    Ben
    I ran 107mph!!!
    so my dyno run is definatly reading lower than it actually is cos thats in a full body 323i bmw in full street trim with full tank of pump fuel 36 degrees air temp and 205 everyday street tyres
    it was my one and only pass too as on the second i broke something in the diff, et was 13.1 but that means jack S#*!#T the mph tells the real story
    a fool remains undescovered untill he speaks!
  2. #137
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    I think I need to wire up my Jaycar DFA, get my car to a dyno, and spend a little time breaking things
    15psi with a nice DFA tune should do something, I hope. I wonder what power i'll make though? I've never put my car on a dyno.
  3. #138
    Quote Originally Posted by 1jzracing
    I ran 107mph!!!
    Good onya!
  4. #139
    Time to update the thread. It appears I was wrong. You can make more than 170kw on the stock turbo's, even when the ambient temp is 42 degrees !
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  5. #140
    Alright, note to self, WTF is wrong with mine?
  6. #141
    Quote Originally Posted by TheToyman75
    goddamn!, what boost was that on?......considering the the work i put into the big single, and only still made 195.7..... lol
    damn!, cant wait to see it out a wsid!
    blake
  7. #142
    Boost is on the right hand axis, looks like it peaked to almost 17psi but then settled to around 15psi.
  8. #143
    GODDAMN!, LOL, looking good but!
  9. #144
    Good onya Rod.
  10. #145
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    Wow, on Std turbos,that is excellent...well done... Could you give us more info on your set up please????
  11. #146
    BLK1G-GTE,
    If you check my members rides thread for my RA28 (Link in Signiture) it has all the details of the engine package and more discussion on the power output.
  12. #147
    Brisbane
    Pube - your dyno graph is a perfect example of why engine management should be used FTW. Makes good power with the stock ECU but if you could trim that AFR back to high 11's or flat 12's it'd do wonders for your midrange.
    Personally I hate those HKS twiddly things but if you get them very cheap and are handy with wiring they can work well as a stopgap... but you'll always get a better result from a good aftermarket ECU install.
  13. #148
    Brisbane
    Note that was in response to a dyno graph on the first page. I didnt' realise there were 7 pages in between... and can't be arsed reading them.
  14. #149
    Aug 2006
    i just upgraded my 1ggte to a single turbo (t04e) with a 3" dump pipe, using a Y pipe i baught off IN 05 NT, it made 200.8 rwkw on 15psi, also have a fmic and a HKS FCON piggy back. Im gettin a ems stinger installed tomorrow with some 7mgte injectors and a bosch 040 internal fuel pump so hopefully should gain a fair bit more power ill update tomorrow,
    if anyone was intrested in the HKS FCON send me a pm, i dyno'd the 1ggte at 175rwkw at 15psi then after installing the FCON 186.2rwkw at 16psi on standard turbo's
  15. #150
    thats just to compare the power curves between stocko's and a gt3071,
    enjoy, blake
  1. *** Dyno Day History Lesson ***
    Last Post: 09-04-2013, 08:50 AM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 12:32 PM
  3. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
  4. std altezza 3sge on chassis dyno
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-12-2005, 12:06 AM
