Hey,
The blue plug is the 12V+ supply for all the electrical components on the motor, like injectors, idle control valve, VVT solenoid, O2 sensor, etc.
Best way to make sure is unplug the computer from the loom, unplug an injector plug, connect a multi meter to the black(with white trace) wire off the injector, and find the wire on the blue plug. Do the same for the other wire, which will be the colour of the injector you use (So Injector 1will be the 34 pin plug ECU plug, and position 10)
The one with the black shrould all the way up to the plug from memory is the traction control plug, the white far left plug. The other white plug out of that cluster is for the dash for oil pressure, water temp, etc. on the dash. I cannot remember for the life of me what the other two plugs are for and I don't have my wiring diagram with me (I live in Canada now, and it's in storage back in Oz)
Do you have the 1JZGTE VVTi wiring diagram?? You really need this file to make sure you have the correct wires connected into the IS300 loom. the wiring diagram will let you use a multimeter to trace those wires to the appropriate device on the motor.
Send me a msg if you want the file and I'll email it to you.
Cheers.
SOLD
