Got a photo of the plugs/ecu ?
				 ECU jzx100 pins
 ECU jzx100 pins
				Anyone have a digram of pins on ecu, with their function?
 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				Best I can do.
http://www.1jz-gte.us/documents/SubDocs4/chaser.pdf
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				Thanks giant tomato, even in Japanese, it looks like a better bet than using a digram for a 2jz supra, which I'm doing now.
				 Re: pic's of ECU
 Re: pic's of ECU
				first pic, the ECU with the plug ins from the engine, these I should not have a problem with, it's the other two out plugs, I got it in a half cut(auto) so most of the pins will be for throttle control,ABS,don't need, etc, some will be for auto and sensors (needed)2nd pic is of two plug ins that I need the pin code for.
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				pic #3 I have the plug ins, with about a metre of wire on each of them, not sure where they all go.
 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				They look identical to the JZZ30/JZX90 diagrams.
http://toymods.net/forums/showthread.php?t=809
Check a few earth pins, and the colours of the major ones to see if its the same.
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				The ECU is the same as my JZZ30 wiring. Here is complete list:
1JZGTE VVTi Computer
Plugs C88 (34P) C84 (22P) C85 (16P) C86 (28P)
Plug C84 - 22pin
Throttle Position Sensor C50-4 VC C84 1 BL-Y
Blank C84 2
Clutch Speed Sensor NCO- C84 3 Gr
ECT Speed Sensor SP2- C84 4 R-Y
Engine Speed Sensor NE C84 5 Br
Sensor Common NE- C84 6 B-R
Throttle Position Sensor VTA C84 7 Y
Airflow Meter C98-2 VG C84 8 R-W
ECT Speed Sensor SP2+ C84 9 BL-Y
Cam Position Sensor G2 C84 10 BL
Cruise Control Computer IDL C84 11 Gr-Y
Throttle Position Sensor VTA2 C84 12 Y-R
Oxygen Sensor OX1 C84 13 W
Traction Control Computer VT02 C84 14 Br-W
Clutch Speed Sensor NCO+ C84 15 R
Igniter C104-5 IGT3 C84 16 BL-W
Igniter C104-6 IGT2 C84 17 R-B
ECT TDCL OIL C84 18 Y-Gr
Oxygen Sensor Heater HTR C84 19 R-BL
Water Temp Sensor THW C84 20 Gr
Airflow Meter C98-3 THA C84 21 Y-B
Throttle Sensor Common E2 C84 22 Br
Plug C85 - 16pin
Traction Control Computer NEO C85 1 P-BL
Main Relay via CA2-8 MREL C85 2 B-OR
TDCL via CI1-18 W C85 3 BL-Y
Fuel Pump Control Relay D1 C85 4 P
Diagnostic Connector TE1 C85 5 LGr
Blank 6
Traction Control Computer EFI+ C85 7 W
VSV Heat Pressure Valve FPU C85 8 BL
Traction Control Computer FAIL C85 9 W-Gr
Fuel Pump Control Relay TPC C85 10 R-W
Traction Control Computer EFI- C85 11 B
VSV Air Bubble EVAP C85 12 Gr-B
Blank 13
VSV (ABV) WGV C85 14 Gr-R
Blank 15
Blank C85 16 N/A
Plug C86 - 28 pin
TDCL via CI1-5 TT C86 1 Gr-R
Neutral Start Switch L C86 2 W
TO CI1-3 P C86 3 Gr-Or
Blank C86 4
A/C Magnetic Clutch ACMG C86 5 W
Meter Check Computer OD2 C86 6 G-R
Cruise Control Computer ECT C86 7 Br-Y
Cruise Control Computer A/D C86 8 Gr-Or
Ignition Switch Power IGSW C86 9 B-OR
Neutral Start Switch S C86 10 Gr
TDCL via CI1-2 TE2 C86 11 Gr-Y
Speed Signal from comb. meter SP1 C86 12 P
Diagnostic Connector + CI2-9 CCO C86 13 LGr-B
Power Supply from EFI Fuse BATT C86 14 B-Y
Blank 15
Blank 16
Traction Control Computer ABS C86 17 R
Traction Control Computer EFIF C86 18 G-BL
Blank C86 19
A/C Computer via CH1-5 A/C C86 20 BL-R
Blank C86 21
Switched power from Main Relay B+ C86 22 B-R
Switched power from Main Relay +B1 C86 23 B-R
Blank C86 24
From CF1-7 Stop Switch STP C86 25 Gr-W
Blank C86 26
A/C High Pressure Switch ELS3 C86 27 W-R
from Relay Block 4 via CF2-11 ELS C86 28 R-Y
Plug C88 - 34 pins
ECT TDCL SLT+ C88 1 W-Gr
No 4 ECT TDCL SLT- C88 2 Y
Traction Control Computer VT01 C88 3 Pu
No 3 ECT TDCL SLU+ C88 4 B
Injector #60 C88 5 R-W
Injector #50 C88 6 W-BL
Injector #40 C88 7 R-B
Injector #30 C88 8 B
Combination Meter ECW C88 8 W-R
Injector #20 C88 9 W
Injector #10 C88 10 Y
No 1 ECT TDCL S1 C88 11 LGr
Igniter C104-4 IGF C88 12 Gr-R
Starter (Manual) STA C88 13 B-W
Starter (Auto) NSW C88 14 B-W
VVT Solenoid C101-2 OCV- C88 15 P
VVT Solenoid C101-1 OCV+ C88 16 R
No 2 ECT TDCL S2 C88 17 R-W
Traction Control Computer ETC+ C88 18 OR
Diagnostic Connector VF C88 19 BL-B
Idle Speed Control ISC4 C88 20 BL-W
Idle Speed Control ISC3 C88 21 Gr-Y
Idle Speed Control ISC2 C88 22 Y-Gr
Idle Speed Control ISC1 C88 23 P
Igniter C104-7 IGT1 C88 24 BL-R
Traction Control Computer E1 C88 25 W-R
Airflow Meter EVG C88 26 BL-B
Traction Control Computer ETC- C88 27 W
ECT TDCL SLU+ C88 28 Gr-W
Knock Sensor KNK2 C88 29 W
Knock Sensor KNK1 C88 30 W
Traction Control Computer IDL2 C88 31 BL-Y
Throttle Position Sensor IDL C88 32 R
Earth CG E02 C88 33 W-B
Earth CG E01 C88 34 W-B
Graham D
Lexus RX350 (no mods yet !!!)
Lexus IS200 / 2.5GT-T (1JZGTE VVTi + Getrag 6 Speed)
Lexus IS200 (wife's car and no mods allowed !!!)
Suzuki GSX750-F
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				Thats it Graham, exactly what I needed, didn't even have to learn Dutch, the tech section of that site would be of use to anyone doing a 1JZ into a 7M supra the guy who picked apart the looms wrote it up real well. www.supras.nl
Thanks to everyone that provided links and info, will post how it works,and any weirdness.
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				Back again Graham,I knew it, too good to be true, The ecu has the same number of pins on plugs,BUT... mine uses different pins, including a lot that are blank on yours, don't have a lot of your colour traces, have some you don't have.Check the part number , I think it will be different, Different computers for manual and auto, mine an auto,what was yours?
Hopefully Toyota kept the same wire codes from model to model,I will check your destinations of wires with a Supra and soarer diagram, if consistant it will help,( and I'll stay mad for a little longer- I hate wiring)
Russ
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				Yes, the ECU's have different part numbers. Mine was an auto that I changed to manual.
I was didn't use the standard ECU on mine - used an Autronic instead.
Good luck with tracing the wires.
Graham
Graham D
Suzuki GSX750-F
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				splatt, have you checked that the pins are labelled inside the computer? Give it a try, if not I have this which might be of some help.
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				buccy
That's my list that I typed in above. Apparently the Chaser version is slightly different from that one.
Graham D
Suzuki GSX750-F
 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				take the cover off the ECu, and all the pins inside are labelled on the curcuit board.
My mates 4AGE ecu had this, as we had 2 ecu pinout diagrams that both said different things, so we opened it up and found the right one.
Eldar.O.
				 Re: ECU jzx100 pins
 Re: ECU jzx100 pins
				Hmm that is strange, mine is a chaser and that list was correct for me. Splatt sorry to ask a stupid qestion but you are looking at the pins when the plugs are disconected from the computer? I ask this because I had one guy counting the pins from the back and wondering why nothing seemed to match up.Originally Posted by grahamd
