Results 1 to 8 of 8
Thread: 2s to 3sge head swap?
    Junior Member Backyard Mechanic sam-131's Avatar
    Default 2s to 3sge head swap?
    hi there i didnt find out what i wanted in the search so i am thing of taking the 2s head and slaping a 3s gen1 head on just wondering if the 3s oil galleries and water inlets on are the same as the 2s head or simply does the 3s's head bolt on and which headgasket would be a goer? (2s,3s)
    i dont really care if small bits and peces dont line up and befor i hear oh it's a crap idea it'll cost to much and so forth well i can get a 3sge head for $50 complete so
    so yeh any info would be great thanks sam
    Melbourne Victoria
    Default Re: 2s to 3sge head swap?
    pistons are different and so is the belt setup and a few other things ,just buy the proper motor
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Don't waste your time you'll be spending a shitload more money on modifications to get it running.
    2s is good for fuel not power. If you want a little extra power get extractors, larger carbie, upgraded cam but its a waste of money either way
    all i care about is if it bolts on which it does really its the crappy head design that holds back the 2s-c non-crossflow ovc poo but if i can bolt on the 3s head and get a tiner head gasket and shim the head up to pump the comp up and a set of sidies which i have plenty lying
    i am doing the same as bolting on a cosworth twin cam head on a 2l escort motor and we all now how the esky cosworth went
    Melbourne Victoria
    sam the 3sge is crossflow and as you say the 2s is not also the 3sge pistons have fly cuts in them for the different valve angle 2s pistons wont have these so you will smash valves into pistons
    fubar that idea got shot down in flames thanks any way
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    so a 3s head will bolt on then??? i am getting whole 3s for cheap and im keeping my 2s block for rego will i have to change the crankaswell or just rods and pistons or... just pistons any help?
    well 4 months ago it did, so it should now?
    You need to bore out the 2S block to fit the 3S pistons to get the head combustion chamber/block bore size to line up at least, probably a lot more things.
    PM sam-131
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. ST162 3SGE Swap (Photo Diary)
    Last Post: 07-10-2007, 10:38 AM
  3. The 3sge oil burner has been pulled down and inspected.
    Last Post: 17-07-2007, 04:15 PM
  4. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 08:15 PM
