Day One
Crane and starter motor delivered. No new purchases.
With the aide of the borrowed crane, I lifted the car (by the engine cross member) about a meter up and set up the jack stands properly. With the bonnet off, work began disconnecting, removing and unwiring everything. ECU removed from interior and all associated wiring. I began to differentiate what things can stay connected to the engine when it comes out and what needs to be removed. I made some good moves and some bad ones (I learnt how NOT to disconnecting the air conditioning...) and I now have everything on the south and west of the engine disconnected, pretty much all of the east and just beginning on the north. I took off the wheels and took the baring nuts off the front wheels. I then went after the suspension cross member, but wasn't able to get the bolts off. With out the space to work the breaker bar, I lubed them up with WD40 and called it a day.
Work will re-commence on Monday night; my goal is to have the engine out before I go to sleep.
			 ST162 3SGE Swap (Photo Diary)
			 Taking it apart is easy, putting it back together is the challenge - make sure you label all the plugs as you disconnect them and bundle screws together with the part they came out with.
