Nope, not even close Zammo.
If you look at the forces on components thru the combustion cycle (google it) you'll see they peak just before TDC and BDC ie when the piston suddenly stops. Nothing about boost effects this, this is simple the piston stopping and reaccelerating with revs. But wait it gets worse, this forces increases exponentially with increased rpm.
So, not only is rpm the main stressor of an engine (not combustion forces) it's the thing you need more off to make power n/a and it gets to nasty levels real quick.
Adding boost will increase combustion pressures so you do need a head gasket up to the task and piston ring lands will become an issue at some stage...but generally speaking, most engines will take boost and easily make 1.5 to 2 times stock hp. Not many (if any) will do this n/a, without significant mods![]()
