Umm... it's not Ben's thread, so you aren't hijacking. In answer to Ben's question, I bought a full gasket kit not too long ago, and the items which you will also need to get is a second O-ring for the dizzy/oil pump drive guide, and the half moon bungs for the back of the head (I got mine new from Toyota).
As for the Megasquirt, if you are not willing to test your skillz on a turbo, and aren't into electronics, don't use the build yourself ones. There is however prebuilt models available, and these are a really powerful bit of gear for a good price. Not sure how the ease of use of the interface is compared with other more commercial models is, however it does give a LOT of info back.
As for the plugs, I have been generally buying new ones. Most are available, and most sensors I have replaced with modern units anyway, which have plugs available new. I am definitely not a fan of using secondhand plugs, as the plastics go brittle, which results in loose connections, and intermittent problems, which are the hardest to solve.
