Page 192 of 392 FirstFirst ... 92142182190191192193194202242292 ... LastLast
Results 2,866 to 2,880 of 5875
  1. #2866
    Ballarat Vic
    Quote Originally Posted by o_man_ra23 View Post
    http://www.zccjdm.com/catalog.php/az...OMOLY_FLYWHEEL.
    Got word back about shipping on this, $105. Brings it to US$604 shipped, which when you do a conversion with www.xe.com, it comes out to AU$647. I reckon that isn't a bad price for a kameari 4.4kg CrMo flywheel. What are the thoughts of the rest of you??
    The way the aussie dollar is going it is worth it. Pity you didn't know some one that could bring it back for you.
    The other thing Kameari were selling were the throttle bodies $US 399 each for weber style. Good valve.
    Roscos
  2. #2867
    Jan 2010
    I think at under $650 for a bolt-on solution is good value... I made maybe 10 phone calls and 20 emails, and came to the kameari solution. Even fabricating from scratch locally isn't that cheap especially if you want the ring gear teeth machined, and what quality will your final product be?. Note however I'm totally biased and am probably just justifying my own stupidity. Neithet have I ever actually used a lightweight flywheel!
  3. #2868
    Quote Originally Posted by bholmberg View Post
    fair enough and alot comes down, as i said, to finding the right fabricator. I have paid around the $300 for the majority of billet flywheels i have had made but i have 'connections'
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    hey has anyone used a dcoe efi manifold on a 18rg, ive been looking in to it a little and i think it could be a good way of getting some efi goodness and still have the awesome induction sounds...
    so basically im looking for some for and against with using this system...
  5. #2870
    Quote Originally Posted by Sagluren View Post
    Great minds...
    (bought second hand so trumpets are too long)
    Not running yet though.
    Pro's: Look and should sound awesome (Although not sure how muted it will be with an airbox over them though)
    Cons: Constantly tight pants when you open hood or press throttle.
  6. #2871
    south australia
    awesome, id be interested on some more info on what brand your setup is. do you have a build thread or something...
    - found the build thread, not allowed to look at it tho....
  7. #2872
    Contact details of said connection?? Did that sort of price include ring gear, or would I have to re-use my existing item??
  8. #2873
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    Quote Originally Posted by 7M-GTE MX73 View Post
    Great minds...
    Yes! Screw the box around them.. I ran the solexes with just trumpets, no filter. The socks kept getting oil from the brake master on them.
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
  9. #2874
    They are EFI Hardware. (www.efihardware.com)
    Indeed I do have a build thread, but its in the members only section.
    (Not much to see at the moment. Thats as far as I have got with them LOL. Still got some fiddling to do and parts to buy before fitting.
  10. #2875
    They are mine The 18RG (many years ago now) reused the stock ring gear.
    What's the opinion out there on Aluminium flywheels?
    THe 22R crank lets me look at 22R flywheels, available in billet steel and aluminium.
    (\__/)
    (")_(")
  12. #2877
    Is there a difference between 22R and 18R flywheels??
  13. #2878
    I read somewhere that the 20/22Rs have 1mm bigger bolts on the flywheel. Same bolt pattern though. I bought a 20R billet flywheel from LC engineering for my 18RG
  14. #2879
    Don't know. But, there is a slight difference between the 22R and 18R bell housings.
    seeyuzz
    river
  15. #2880
    That could be because they used different gearboxes?
    I raed that 22Rs use 12mm bolts, 18Rs use 10mm.
    I haven't measured them because I am lazy.
    I saw a photo once of an 18R flywheel next to a 22R flywheel. The 22R flywheel had a wider clutch contact surface. I don't remember if the clutch itself was any different, though.
    (\__/)
    (")_(")
