Results 16 to 30 of 32
Thread: surge tank setup: is this dodgy?
    Default Re: surge tank setup: is this dodgy?
    With the lift pump coming in right at the bottom... I have mine like that but it means most the fuel can drain back to the tank so the efi hiflow pump may run dry for awhile when it first starts up.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Using sleeved bolts will not block the top port as long as the sleeves are long enough to provide clearance - the sleeves will be butted up against the bodywork holding the tank down. You will find that it will not be able to move and should have decent clearance.
    just mount it the right way or get another one! for $100 or so its not worth mucking around with!
    make a big arsed C-shaped bracket out of 2-3mm sheet steel.. mounts it right way up, and gives some road debri protection also....
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    Quote Originally Posted by kingmick
    the point of this thread is to ascertain the right ways to mount the thing. its hard to find a tank for $100 with the inlets in the right spots. we dont all have stacks of cash floating around
    I have a Crown
    well thats cool, should think about the way you respond, because now you dont get to know the easy way to fix it for next to nothing! suppose we live and learn
    Here you go, one for $100
    http://www.tweakit.net/shop/product_...roducts_id=126
    If you want to use it you could always go find an alloy welder and get them to weld an extra inlet at the new top.
    New Zealand
    Thats not really a helpful post, if you don't intend to share your knowledge then why even bother posting. Probably going to cost me some rep but your attitude lately and air of superiority doesn't really seem to sit that well with the whole point of Toymods which is helping fellow Toyota owners.
    Callum
    pull you head in! i was about to and came in he to then saw his last post!
    i thought telling him that way was the best way!
    New Zealand
    Pull my head in? Why not pull yours out of your ass. A vast store of knowledge you are not willing to share is no good to anyone around here.
    i share what the hell are you talking about?lol
    Mick does share his knowledge, alot.
    But i think that we should all shutup and keep the post on topic.
    yeh i found that one, but its quite small. its only 650ml
    I have a Crown
    sa
    I got mine custom made to suit the undercar mount setup like your doing for about $100.
    To avoid the fuel draining out when its not running just strap the fuel line up to the floor. Use what you have because it will work fine. If you wanted to make it perfect get another outlet welded near the top but its just not needed, put it in and go have some fun!
    Ghetto Goodness Automotive Encyclopaedia Ghetto-AW11's Avatar
    doh.adffasf
    Homebrew, triumph triple, turbo aw11
  1. Min size of an effective surge tank?
    By thomasbl in forum Tech and Conversions
    Last Post: 02-07-2006, 11:38 PM
  2. how to fit a surge tank?
    Last Post: 27-05-2006, 07:29 PM
  3. Replies: 1
