No, 1450 to 1460mm. I had to run FWD offset wheels to fit it in my KE70. As said the KE70 is 1400 and I think TE72 (T18) is 1410. Mark (AE25) will have exact measurements somewhere though.
Callum
Isnt a MS 112 crown 1410 mm wide .
Dave
Callum
can anyone confirm a diff that is interchangable with st141 BW?
i was hoping ra60 might but it doesnt seem to according to the charts
Hi guys,
Im pretty new the world of toyota I have a IS200 With a 2JZGTE that is making close to 400RWKW now the standard torsen LSD is not going to hold up to this sort of abuse for long and I want to put a supra diff into the car. I have been unable to find much information about the series diff that comes in the IS and I'am wondering if anyone can help me out? any info would be really helpful
thanks
Don't quote me on this as I'm running off memory, but I think the IS200 has an A Series, but it's smaller than the Supra A Series.
I'm probably completely wrong, as I have a really shit memory.
Not sure if this has been found before
Is American but might be useful
diff codes, dimensions etc
http://members.iinet.net.au/~stepho/diff.htm#diffcodes
Not sure if it's been covered yet, but anyone know what width the diff would be in a 74 hiace, being the same era has the hilux rn25 etc, do they have the 1370mm wide g series diff?
'74 TA 22- 2tg with massive cams!
"Full carpeting, tinted glass, a tachometer and a Rally-style electric clock."
74 is an RH10 yeah?
From memory they're 1470mm.
Do you have access to one?
Edit: My memory might be going off the YH50 Hiace - http://akb.norbie.net/Public/AxleList.aspx?ModelID=8
The hiace diffs have always been alot wider then the 2wd hilux ones afaik
I have a jap spec TE71 it came out with a disc braked T292 4.1 ratio 1410mm wide have since done conversion to hilux LN106??? diff I think it been a long time ended up being about 25mm narrower each side. Hiace housings were definitley alot wider nearly 1600mm axle face to axle face
hi,
i hav found a diff F362 from LS110R crown...
any1 have info about this diff especially the gear ratio?!
is it strong enuf 2 withstand the brute force of 1JZGTE with ~500hp?!
if it has no LSD, can it be fitted with aftermarket LSD?!
tQ~
F362 means it is a 4.778:1 ratio and non LSD. You have an MA63? If that came with an LSD you can put that on the Crown ratio. However, the stock LSDs might not do too well behind a 1JZ. Norbie on here has a F series with Truetrac LSD behind a 2JZGTE in an MA61 and that has handled the power.
Standard manual (or stick shift on your side of the world) JZA70s have a 4.1:1 ratio. That 4.778:1 in the crown would be stupidly low. A good condition F series diff with a decent LSD (like a truetrac) should be able to handle a 1JZGTE
