Originally Posted by
ToyTA22
You unluckily need to split main case and change selector rails over as well as rear housing. I am going to fit close ratio TRD gearset in a AE86 box but fit into TA22 so I need to do the same thing. The 3t box, out of memory, should be same length from front of gearbox main case to rear end of output shaft. AE86 and TA22 I just checked are same length. Should not need to alter drive shaft, check output shaft splines, TA22 has 20 splines AE86 has 22 splines. So may need driveshaft front yoke to suit.
If you need more info just ask, if I can't answer someone else most probably will.
