The ke70 had the k40 or k50 so im pretty sure it would fit in. But I would also think that these gearboxes would be easy to get??? have you searched around?
Hi all,
I have a what I think is a K50 gearbox behind my 4AGE engine. Its the cable clutch type which I think is from the AE85/AE70. Now this gearbox has done me well but it has started to make noises and start to scream in certain gears. Because these gearboxes seem to be almost non existant I am wondering if the gearset from the KE70 (K series engine) gearbox will fit and if the ratios are the same or not? Basically if i source a KE70 gearbox then will the guts fit my gearbox?
Can anyone help me here?
Automobile Status: Forward Movement.
You'd want a T-50 for the 4AGE mate, Don't know how the K-50 is behind your 4AGE,
1977 Toyota Corolla KE30 1GGTE http://www.toymods.net/forums/showth...post7372821977
1987 Ford Falcon XF S Pac
I have a T50 in my shed waiting to go into my next project.
The K50 was chosen for my Suzuki Sierra as it is cable clutch and made things easy. The gearbox has held up surprisingly well considering. Even offroad in 4wd where there would be some pretty strong forces on the box it has done extremely well. So to simplify things Im quite prepared to stick with it. As long as I can get confirmation of the KE70 K50 being the same internally then thats what I will source. My gearbox, the AE70 K50 is almost impossible to find. Really depends on what I can find I suppose.
id be saying you have a T50 behind a 4a
and i doubt K50 internals would fit.
T50 are relatively common, although takumi and dorifto boiz do keep braking them
im sure you could pick one up out of an ae71 for not too much. esp if you buy the whole car haha
K50 was available behind the 3A in the AE85 and AE70 (possibly others). Its commonly used in NZ as you don't need to convert to hydro clutch, make 4A conversion into K series Corollas and Starlets pretty easy. As long as you know what your doing, swapping the internals overs with a K series K50 should be relatively straight forward.Originally Posted by Trent-KE30
Callum
4A's came with T50;s
4K's came with either K40 or K50
i dont think there is a bell housing avaliable to enable you to use the K50 behind a T50.
that said, this "AE70" of yours, doesnt exist.
theres the KE70, and AE71, its not a misprint, since youve mentioned it a few times already...
Id be inclined to beleive your after a T50.
they can be had for under $150, and are decent until you start putting them through alot.
Eldar.O.
You are wrong, there is a K50 with an A series bellhousing. Was not supplied new in Oz, but then Oz isn't exactly overflowing with everything Toyota known to man.Originally Posted by EldarO
KE70 uses 4K and K40/50
AE70 has 3A with A bolt pattern K50
AE71 has 4A with T box
AE85 has 3A with A bolt pattern K50
AE86 has 4A with T box
For a box/car that doesn't exist I've seen a hell of a lot of them.
Callum
Eldaro..
read Callums post..
there IS a T50 behind A series motors.
Bazooka,
there ARE internal differences in some K series boxes... so far they have been confined to the layshaft bearings/shaft, and the lengths of the selector rods...
i think the early boxes also have different sized bearings but cannot remember for sure..
since selector shafts can be pretty much swapped between boxes... just use your current ones
the actual gearsets, as long as the input and output shaft bearings are the same diameter... should swap across with no hassles.
the actual layshaft appears to be the same diameter between different series of boxes...
if yours is worn near the front (as about 50 billion of them are) it is possible to reverse it 180deg, grind a new notch on the other end (you'll see when you pull it out what i mean) and then get a bit more life out of it...
even if the needle rollers between the layshaft gear and the actual shaft are different, it should still swap across..
there are small differences int he thrust bearings between years, with some larger diameter ones.. but if yours are ok, keep them..
so basically.. if you get a KE70 box, then it is very likely it will swap across.... a KE55 should also, but there may be small differences.
so much for double posts being prevented![]()
Adding to WDE BDY's comments. T50 would be hydrolic clutch wouldnt it? And he has a cable clutch. But im not expert so I could be wrong.
Most were, but there are some rare cable T series bellhousings floating around.Originally Posted by pushrod_POWA
Callum
Edit: there are also cable and possiblely hydraulic T box to K engine bellhousings and even a K engine to W box bellhousing![]()
there are hydraulic clutch K to T bellhousings.
there are CABLE clutch K to T bellhousings also
most K to K are cable.
most A to T are hydraulic
A to K is usually cable?
read my post Stu.Originally Posted by oldcorollas
the term "i think" is not a clear-cut substitution for the term "i know"
Eldar.O.
rumours are based on "i think"Originally Posted by EldarO
facts are based on "i know"
toymods is about spreading facts, not rumours
but technically, there are no "bellhousings" from A to K.. as K never had a seperateable bellhousing![]()
