Results 1 to 15 of 18
Thread: MX83 Grande aftermarket head unit install.
    Nov 2012
    Default MX83 Grande aftermarket head unit install.
    Hi there, I have a 1990 MX83 Cressida Grande and I'm trying to do an aftermarket head unit install.
    Now, I have bought harnesses from Aerpro,
    namely,
    Toyota ISO Connector
    and
    Clarion VX400A Connector
    However, I got stuck when I wanted to splice the factory harness into the Toyota ISO connector. I'm at a loss as to which socket to splice as there were 3 of them. Any help would be appreciated.
    Default Re: MX83 Grande aftermarket head unit install.
    Have you taken out the amplifier?
    Jealousy is a curse
    Nov 2012
    I take it that the amp is that bulky thing that the 2 shorter looms plug into? If that is the one, I haven't taken it out yet.
    take it out you do not need it . Use the plugs that connect the amplifier to the car harness
    Jealousy is a curse
    Nov 2012
    So it means I'll just use the plugs in the 2nd and 3rd picture?
    take out the amplifier and use the plugs that remain
    Jealousy is a curse
    Nov 2012
    A colour guide for it would be awesome if you have it. Cause the ones I found on the US electrical wiring diagram were all off.
    You should not need wiring diagram if you have the toyota adapter for the new head unit
    Jealousy is a curse
    Nov 2012
    They don't exactly fit.
    Nov 2012
    What if I spliced it from the amplifier output?
    I've established that this wire links to the top controls.
    all in all, halp plz!!!!
    What does your adapter look like ?
    Jealousy is a curse
    Have you tried plugging the adapter into the plugs you removed from the amplifier?
    Jealousy is a curse
    Nov 2012
    Yes. I have tried plugging them into the wires from the amplifier. The plugs are not the same and they don't fit.
    Below is the harness I got from aerpro for earlier model Toyotas apparently.
    Brown and black goes to the head unit adaptor. White goes towards the Toyota.
    Are these the plugs you tried to plug into your adapter?
    Jealousy is a curse
    Nov 2012
    Quote Originally Posted by madmont View Post
    Yes. However, they do not fit.
  1. Toyota crown uzs131 head unit install help
    By whiterolla in forum Tech and Conversions
    Last Post: 17-04-2012, 11:17 PM
  2. Replies: 1
    Last Post: 17-11-2011, 09:35 PM
  3. MX83 Grande Stereo Install
    Last Post: 25-09-2009, 02:27 PM
  4. 91 Cressida GLX Head unit install
    By Kev in forum Tech and Conversions
    Last Post: 23-07-2006, 01:07 PM
