Have you taken out the amplifier?
Hi there, I have a 1990 MX83 Cressida Grande and I'm trying to do an aftermarket head unit install.
Now, I have bought harnesses from Aerpro,
namely,
Toyota ISO Connector
and
Clarion VX400A Connector
However, I got stuck when I wanted to splice the factory harness into the Toyota ISO connector. I'm at a loss as to which socket to splice as there were 3 of them. Any help would be appreciated.
Jealousy is a curse
I take it that the amp is that bulky thing that the 2 shorter looms plug into? If that is the one, I haven't taken it out yet.
take it out you do not need it . Use the plugs that connect the amplifier to the car harness
Jealousy is a curse
So it means I'll just use the plugs in the 2nd and 3rd picture?
take out the amplifier and use the plugs that remain
Jealousy is a curse
A colour guide for it would be awesome if you have it. Cause the ones I found on the US electrical wiring diagram were all off.
You should not need wiring diagram if you have the toyota adapter for the new head unit
Jealousy is a curse
They don't exactly fit.
What does your adapter look like ?
Jealousy is a curse
Have you tried plugging the adapter into the plugs you removed from the amplifier?
Jealousy is a curse
Yes. I have tried plugging them into the wires from the amplifier. The plugs are not the same and they don't fit.
Below is the harness I got from aerpro for earlier model Toyotas apparently.
Brown and black goes to the head unit adaptor. White goes towards the Toyota.
Are these the plugs you tried to plug into your adapter?
Jealousy is a curse
