Page 9 of 18 FirstFirst ... 7891011 ... LastLast
Results 121 to 135 of 270
Thread: MRP 7age/9age 1900cc Stroker Kit
  1. #121
    Jul 2008
    Auckland
    Default Re: 7age/9age 1900cc Group Buy!
    Ok guys we have the following add on options to the kits:
    ARP Main stud kit $130NZD
    ARP 4age 16v Head Stud kit $180NZD
    ARP 4age 20v Hea d Stud kit $150NZD
    Brand new OEM crank sprocket with 2-key way cutouts to suit our cranks (And offset to bring the crank in timing with the cams) $120NZD
    Let me know if you want to add any of these options to your kit.
    Now 9AGTE 410kw atw
  2. #122
    Jul 2007
    20v head stud kit and crank sprocket please
  3. #123
    Feb 2010
    Auckland
    Bugger those are some good prices.. I was all excited so I got my ARP stuff a couple weeks ago. nevermind.
    Put me down for a crank sprocket please
  4. #124
    Jul 2008
    Auckland
    Done and Done.
    Now 9AGTE 410kw atw
  5. #125
    Mar 2010
    Mississippi
    I will need a full ST 20V gasket kit
    thanks wd
  6. #126
    Jul 2008
    Auckland
    ome updates on first post regarding add on options.
    Now 9AGTE 410kw atw
  7. #127
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Hi Badza,
    I just need main studs and the two cutout crank sprocket.
    Thanks.
    == 4AGZE SC14 Supercharged ==
  8. #128
    Jul 2008
    Auckland
    Quote Originally Posted by nick.parker View Post
    Hi Badza,
    Thanks.
    Added to your list.
    Now 9AGTE 410kw atw
  9. #129
    Canterbury
    I verified from a couple of sources that 1ZZ and 2ZZ rods are 19.7 mm wide (big end) and 4AGE rods (since we're using 4AGE bearings) are 21.8 mm wide.
    Just thought I'd share that info - that's going in the right direction I'm thinking - we will have a wider bearing than another Toyota engine with a similar stroke....
    Nick.
  10. #130
    Jul 2008
    Auckland
    Wider bearings = more load capability
    Thought about using the 1zz crank with custom rods & pistons but it would mean alot of mods to the block to make it fit nicely. Plus the extra stroke would bring the rod/stroke ratio down into the high 1.4X.
    Any how we will have 2 light weight cranks done very soon. These have been done with knife edged counter weights. So shout out which crank you prefer!
    The rest of the cranks will be the same as the TRD atlantic ones:
    Now 9AGTE 410kw atw
  11. #131
    Oct 2009
    If it was me Id go knife edged
  12. #132
    Jul 2008
    Auckland
    Quote Originally Posted by shrike View Post
    The TRD style ones were done as this would see less harmonics on the crank due to the large counter weight design. But of course will cause a bit more drag and take a little bit of power.
    Now 9AGTE 410kw atw
  13. #133
    Mar 2010
    Mississippi
    Seeing I am shooting for NA for a daily driver with as much low end torque as I can get, put me down for the TRD style one.
    wd
  14. #134
    Jul 2008
    Auckland
    Quote Originally Posted by wrenchdad View Post
    wd
    added to your list
    Now 9AGTE 410kw atw
  15. #135
    Jul 2007
    ill take the FA style one as I presume this one is better for boost yes? being beefier and whatnot..
  1. 7age: how to?
    By iflylo in forum Tech and Conversions
    Last Post: 03-12-2015, 08:02 AM
  2. 9age??
    By Bazooka in forum Tech and Conversions
    Last Post: 06-10-2012, 08:44 PM
  3. 7age 20v stroker?
    By 13anshee in forum Tech and Conversions
    Last Post: 29-08-2011, 10:03 AM
  4. 20v BT head on a 7AGE
    By chadix24_7 in forum Tech and Conversions
    Last Post: 09-03-2006, 10:00 AM
