Yes girdle will go on top of the caps.
Will go over the oil pump holes as well.
Basically a 1 piece girdle.
I hope to build a 300hp n/a 9age one day soon. Next is to design a affordable dry sump bolt on system.
It reminds me of "Chuck Norris doesn't do push ups, he pushes down the the earth" - that made me laugh the first time anyway!
Also keen on a girdle if its not too expensive - if not now, then down the track.
This girdle would go on top of the caps right?
As opposed to replaced the caps?
Nick.
== 4AGZE SC14 Supercharged ==
Now 9AGTE 410kw atw
A dry sump system is exactly what I am looking at at the moment. I don't want to spin another bearing or break the stock oil pump gears.
Now 9AGTE 410kw atw
I know about those and their high price, it still wouldn't stop the oil pressure drop at higher revs.
Why would the oil pressure drop at high RPM? Its a positive displacement pump, provided its got oil your sweet.
I have no idea, however I have had multiple reports of it and even seen it in a video of it happening in real time.
Hey Bazda, what's your girdle going to be made of and how thick? How about some hardened steel reinforcing straps instead to go over the mains like the Tomei kit?
My guess would be cavitation/thrashing etc - think about how fast it's spinning at 9-10k+ rpm and what that's doing to the oil as it contacts it. The pump is designed to operate effectively at a certain speed range, and like a propeller on a boat it works efficiently at a design speed and cavitates at higher speeds. Basically it has a 'drive ratio' a bit like a diff so you need the right diff ratio for the speeds you're trying to drive at. 7k rpm limit to 10k rpm limit is basically a 50% increase.
Toymods Club Member
Sam,
I can make anything. Instead of the tomei straps I could easily make something similar but join all those straps together as 1 flat plate. That would be reasonable cheap to make out of steel. The tomei steaps help with cap flex but doesn't help with block flex.
The girdle I want to make would be 12mm thick alloy and would attach to the sump bolts.
Now 9AGTE 410kw atw
Now 9AGTE 410kw atw
Now 9AGTE 410kw atw
Cool man.. I'm still thinking about it at this stage. weighing up the cost of a R154 vs the "hard to findness" of a decent W58.
I know it's hard to say without the box to go off, but any idea how you'd go about it? Adapting a 1j or 7m bellhousing to a 4a block would be awesome but difficult? so I'm assuming you'd look at making a sandwich plate to mate the R154 to a 4a bellhousing, but if so which one? T50 bell too small? niteparts 4a-w58 maybe?
Sorry for the questions, just trying to gauge cost and parts required before I commit and buy a box![]()
Now 9AGTE 410kw atw
