Page 10 of 18 FirstFirst ... 89101112 ... LastLast
Results 136 to 150 of 270
Thread: MRP 7age/9age 1900cc Stroker Kit
  1. #136
    Jul 2008
    Auckland
    Default Re: 7age/9age 1900cc Group Buy!
    ill take the FA style one as I presume this one is better for boost yes? being beefier and whatnot..
    Yes that's correct.
    The light one crank is for the N/A guys who want the best possible response.
    Now 9AGTE 410kw atw
  2. #137
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Quote Originally Posted by Bazda View Post
    Yes that's correct.
    Formula Atlantic chunky style for me too. I like the idea of less Harmonics. Thanks.
    == 4AGZE SC14 Supercharged ==
  3. #138
    Feb 2010
    Auckland
    Chunky monkey for me too thanks.
  4. #139
    Jul 2008
    Auckland
    Noted for both of you
    Now 9AGTE 410kw atw
  5. #140
    How bad is the potential increase in harmonics? Isn't it more a case of less mass in the counterweights, so less effective at dampening them - but you should be fine if the rotating assembly is well balanced? Or do you still need a good harmonic balancer as well as the thorough balance? Or even then are you still running a risk?
    Toymods Club Member
  6. #141
    Jul 2008
    Auckland
    Balancing the crank is easy, any crank design can be balanced.
    Balancing the counter weight to the weight of the rod/piston is another issue. The more balanced these are the smoother the engine will run. And also having larger counter weights will dampen out the harmonics better as well.
    All race engines I would suggest running at least the oem balancer which in theory isn't really a harmonic balancer, it really just dampens out the harmnics produced from the alt/ps etc.
    Alot of people knife edge their cranks to reduce the rotating mass. If too much material is removed your engine can easily kill bearings from the induced harmonics. In saying that the ones we are making still have a fairly good weight to them and would not be an issue.
    Now 9AGTE 410kw atw
  7. #142
    Jul 2008
    Auckland
    Some goods news - CP have finished the pistons
    Now 9AGTE 410kw atw
  8. #143
    Jul 2008
    Auckland
    Thinking about doing a billet alloy crank girdle as well now.
    Who would be keen?
    It would lower the sump down around 10-12mm.
    Only issue is custom arp main studs would be needed.
    Now 9AGTE 410kw atw
  9. #144
    Top End
    Yeah thats the go
    ive showed GB to some ppl and some have reservations about the strength of the 7 block my answer to them is its a good buy and the money saved could be put towards a crank girdle
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  10. #145
    Jul 2008
    Auckland
    Quote Originally Posted by Zammo View Post
    Yeah thats the go
    7a blocks are damn strong.
    Even adding crank cap add ons will help alot. But a girdle is going to be the best option.
    We will come up with a girdle which will be very affordable and not some crazy ridiculous price
    Now 9AGTE 410kw atw
  11. #146
    I am interested in the girdle by itself.
  12. #147
    Jul 2008
    Auckland
    Quote Originally Posted by Sam_Q View Post
    I will post up a new thread once we have finished the first one.
    Now 9AGTE 410kw atw
  13. #148
    Feb 2010
    Auckland
    Could be keen. Price dependant tho due to the ratio of cost vs sharpness of objects thrown by wifey
  14. #149
    Jul 2007
    also tentatively keen.
    this build is getting out of hand very quickly lol.
  15. #150
    Jul 2009
    All apart of Bazda's plans for world domination
    All these insane builds will delivery a power output so high it will rotate the earth to a new axis and New Zealand will geologically become the new Japan
  1. 7age: how to?
    By iflylo in forum Tech and Conversions
    Last Post: 03-12-2015, 08:02 AM
  2. 9age??
    By Bazooka in forum Tech and Conversions
    Last Post: 06-10-2012, 08:44 PM
  3. 7age 20v stroker?
    By 13anshee in forum Tech and Conversions
    Last Post: 29-08-2011, 10:03 AM
  4. 20v BT head on a 7AGE
    By chadix24_7 in forum Tech and Conversions
    Last Post: 09-03-2006, 10:00 AM
